Tech@ZWO Still doesn't working, a couple days ago they upload a beta version of the asiair plus, that fix the sync to mount error, BUT still having some problems using the asiair pro.
I send this to ZWO ASI air page (on facebook) testing later this beta version of the ASIAir App:
https://www.pgyer.com/air_south
When I start the ASIair Plus it indicates my correct location on the mount, but the Skymap continues to point to the north celestial pole.
When executing the Home Position, the time in AR changes from 16 hours to 4 hours (12 hours difference, but without moving the engine) and in DEC from +90° it goes to -89°, completing a turn of approximately 180°. Just there, the skymap indicates that the mount is pointing at the South Celestial Pole.
When I indicate to go to an object (Canopus star for example), the engine moves with inverted direction (when the location on the mount is in my position and recognize that i'm on the southern hemisphere) For example, canpus at this time is passing trough the meridian to the west, so the counterweight has to pint to the west, BUT NO, goes to the east and the DEC goes to tie oposite direction.
The INDI driver of the mount indicates my time in UTC -5, but in my location I am in UTC -3.
When I use the ASIair on another mount (NEq6 with EQmod), the Plate Solving doesn't work anymore (when before the firmware update was working ok).
Textme to my mail maxijfalieres@gmail.com and maybe we can chat to get solution to this.
Thanks!
