gammerpc I would like to run both my rigs from my iPad at the same time
You can only get the ASIAIR app to switch between the two ASIAIR devices from the ASIAIR Settings window.
The outer layer of the app (that splash screen) will essentially relaunch the ASIAIR app itself with the "Switch Device" button.
So no, it is not possible to concurrently monitor two different ASIAIR devices on a single ASIAIR app. The app can only switch between the two mounts.
