I own an ASI174mm and try to use it for guiding. Now I encountered some strange behavior. When I use my asiair with my camera and I set exposures >1 sec I get an error message that something could be wrong with the cable/camera etc. because it seems to be timing out.
I replicated this behavior with Firecapture and encounter the same problem then on my computer. As soon as I set the exposure to 1 sec the problem is solved and it works flawlessly, both in the Asiair and in firecapture.
When I try to do the same with AsiCap on my macbook I don't encounter the problem and it just takes the longer exposures.
Does anybody have an idea what could be going on? As it happens on 2 separate devices somehow I don't believe it's a driver issue, but on the other hand Asicap doesn't show it, so I'm a bit stuck. I'm using the Asiair v2.0 software, and I'm pretty sure that before on older versions it worked also.
Hope somebody has a solution for this.
