avdhoeven I ordered a new cable, but somehow I don't think that is the issue.
The fundamental issue is not the cable, but the USB port in the camera.  The USB ports in ZWO devices don't appear to be designed with enough engineering margins (voltage, frequency and temperature).
If that is the problem with your camera, by "tuning" with different cables, the ports could often be coaxed to work.
If you are using the USB cable that came with the camera, try and replace that with a good cable that is just long enough to connect your camera to the ASIAIR.  Find a cable that advertises 20 AWG conductors for the voltage and ground pair.  Do not be tempted by thin cables.  And certainly do not use cables that are unnecessarily long to require them to be folded or coiled -- coiling a cable causes all sorts of problem with unshielded data pairs.
ZWO keeps recommending that people try with different cables, without admiting that the root problem is that their USB interfaces are not designed with sufficient margins to handle all USB cables.
