thebruce Ive just been leaving out for a few days at a time in SF while powered on so save me the hassle of re-polar aligning.
Ah, you should be able to turn off power in the daytime. (Unless you are doing Solar Hα work, that is.)
Polar alignment is purely a mechanical adjustment. It ensures that the polar axis of the mount point close to the actual north celestial pole (NCP). As long as the mount does not move between one night and the next, you do not need to re-do polar alignment, whether the ASIAIR is turned on or not.
You do need to make sure that your dog or cat (or a deer or racoon) does not brush against the tripod legs since we are talking about arc minutes to arc seconds type precision. One end of a moment arm of 1 meter (e.g, spread of a tripod leg separation) only needs to move 0.3 mm up or down to produce an arc minute of change.
So, even if the ground under one tripod leg settles by only 0.2 mm, you would normally want to re-polar align. But in this case, you need to re-align even if the ASIAIR had been powered on, anyway.
The ASIAIR power has nothing to do with polar alignment; in fact you can polar align using a PoleMaster or with SharpCap, and proceed to use ASIAIR without going through the ASIAIR polar alignment process.
Temps here are never really too hot or too cold.
Yeah, but you have that pesky Marine layer :-).
Another question on the camera and cooler. Do you turn the camera or cooler off when not using?
I turn mine off until I need it for imaging, just because fans have limited time before they fail. And I really don't want them to fail while the Peltier cooler is running. Something will melt with 36 watts of power going in, and no fan to extract the heat. I don't think ZWO cameras come with a fail-safe mechanism to turn off power to the Peltier device if the fan ever stops.
Plus, cameras like the ASI2600 have a penchant to leak thermal greese; you don't want to stress the Peltier cooler. Even at times that I do have the cooler on, I would monitor the cooler power so that it does not go above 85% to 90%. On warm Summer evenings when the cooler is more stressed, I would back off and live with a higher sensor temperature (need different set of dark frames, of course). So far, I have been lucky that there is no grease leaks on my two ASI2600 (a color and a monochrome) but I don't know how long my luck will hold. It is something you might consider -- it just depends on how much risk you are willing to tolerate.
