Can the next build version have the feature of park position and home position?
The park position is whatever you set it to. People with roll-off roof observatories, often want a park position where the counterweight arm is horizontal and the scope is horizontal. This minimizes the height of the rig to allow for roof clearance.
Thanks
    YES, I also want the park feature for my Comec 10Micron HPS3000 mount. There are a lot of roll-off roof users out there...
    neptune2015 there is home but it's buried at bottom of mount settings. Would love a much easier/faster way to go to mount home. great suggestion on park and making it easy to get to.
    Beta 2.1 even worst experience for my CGX mount than the latest stable version (if that is even possible). I will sell this Asiair Plus, it was a total dissapointment.
    lucasdanda I have the exact same issue. I posted a bug report via the asiair app too.
    Alignment sometimes takes 45 minutes and varies widely in the offset reported between retries. I just have to guess when I think it's good. It worked much better in 1.x for me too.
    Can anyone confirm whether they fixed the centre/GOTO bug when using ST-4 on a Star Adventurer etc? I'm still stuck on 1.9 because of this bug and really hoping it's fixed in 2.1.
    Old problem and you still have not fixed it. Portrait mode to landscape still hangs up on boot up . Android tablet in my case.
    I have to reboot my tablet every time ( if I forget to put my tablet in portrait mode) because you have not fixed this issue.
    I'd really like to leave my tablet in landscape mode and not have to turn it just to boot up the ASIAIR.
    This issue has been a long time in needing a fix. Can your code writers fix this or not?
    Kring I have an Android tablet that has the same issue. This has gone on for a long annoying time. It really needs to be fixed. It is a ASIAIR app issue. I have to reboot my tablet each time I get hung up with this portrait view. It cuts off half my screen.
    7 days later
    PMTeam@ZWO
    Taking the exposure to the limit, we continue with the marks in burnt areas, Sony a7r2 camera.
    Version 2.1 10.74
      fmg Taking the exposure to the limit, we continue with the marks in burnt areas, Sony a7r2 camera.
      Looks like saturated pixels are not handled properly by ASIAIR. The cyan artifacts look suspiciously like saturated red pixels have numerically wrapped around to zero, but the green and blue have not yet saturated. While the red artifacts look like green and blue have saturated.
      It is either a bug in Preview (how data from the camera are scaled to 8-bit RGB when displaying to the screen --for example, not truncating RGB values that are over 255 [for example, masking with 0xff, instead of a comparison with 255]), or it could be a bug when converting a 14 bit image into a 16 bit image.
      You can try to save the image (that download icon below the exposure value) to the tablet's photo album. If that image is OK, the bug is just in Preview, and your images actually survive, so you can just ignore the blemish on the screen.
        PMTeam@ZWO w7ay I think it is not a problem with the Preview, the problem is attached to the light file, I leave a capture of the Alnitak star with a very low exposure ISO400, 30 sec. and the core of the star continues to come out saturated, the capture taken from Pixinsight.
        google translator
        • w7ay replied to this.
        • fmg likes this.
          fmg I think it is not a problem with the Preview, the problem is attached to the light file
          You are right. It looks like it is not even a wrap around, but a hard clipping of a 16-bit number, but to 0 instead of properly clipping to 65535.
          Send an email directly to asiair@zwoptical.com to report it. You are more likely to get a response (notice that ZWO doesn't even have the courtesy to respond to your original posting here).
          • fmg replied to this.
            7 months later
            PMTeam@ZWO Celestron Advanced Series GT mount does not perform correctly at meridian flip. It’s getting goto commands that are probably wrong, sending the telescope into the ground while trying to auto center the target. This is a long standing issue.
            fmg Sorry for the trouble, we solved this problem, and will release the public beta version as soon as possible.
            We really appreciate if you would like to test it.
            Thank you for your support
              Dspital Thanks, We will release the download link in the forum as soon as possible.
              9 days later
              Tech@ZWO Thank you for your response, I would be happy to try the Beta version and see if the problem has been corrected.
              Google translator
              3 months later
              I am getting a lot of “gain -1” with this beta. I change it back to 110, and it sticks for a while. Then it’s back to -1. Weird.
