Just installed 2.1.52 (10.73) and it did connect using LX200 at 115200 baud, three tries though. No bueno, does nothing for my NYX-101, no control of any kind. I have two ASIAIR's, Pro and Plus. I will only update one because the other is working on the old versions mentioned above. I will keep trying each new update hoping it will work with all functions working
The older version isn't perfect. Manually it has a range of 1 to 4. I believe 4 is fastest but it is almost imperceptible. At least I think it is moving, I could be wrong because it is imperceptible. I must like that word 'imperceptible' as I used it three times already. However, when an object is selected it moves quite quickly with great command and very nicely.
I realize, as I hope anyone using a harmonic drive does, they have tremendous torque. I mean it can bend and break things kind of torque. It is not at all like a standard worm gear drive that stops on a breath of air, ok maybe a stiff breeze with a rigid dew shield. The point is, be careful.
I will be happy to help in anyway I can. Otherwise I'll keep my fingers crossed hoping it will work soooooooon!!
