My ASI2600MM is giving "Exposure Failed" to every attempt at an image. Replaced cables, rebooted everything multiple times, changed on and off every setting. If I set my guide camera asi120mm to the main camera it works, but the ASI2600mm set as the guide camera fails with an error on the guide screen. Tried leaving everything unplugged for 20 minutes. Nothing.
I connected my ASI533MC to the same cables (just unplugged the 2600 and plugged in my 533MC in place, and it works great. Plug back in the 2600mm and 'exposure failed'.
It was working just fine for polar align, auto focusing, but when I set to autorun and left it, it errored out. See auto run log below. I stopped auto run twice, once to turn on guiding cause I forgot and again to change the 20 light frames to 15 cause 20 SHO would take too long. When I started auto run again at the end, I get "2023/02/15 20:07:27 Exposure 600.0s image 1# failed" now it wont take an image. Anyone heard of, or seen a solution to this?
Log enabled at 2023/02/15 19:44:19
2023/02/15 19:44:19 [Autorun|Begin] NGC1499 Start
2023/02/15 19:44:19 Target RA:4h3m47s DEC:+36°25'44"
2023/02/15 19:44:19 Shooting 20 light frames, exposure 600.0s Bin1
2023/02/15 19:44:19 Filter change, L change to H
2023/02/15 19:44:22 Start Tracking
2023/02/15 19:44:22 [AutoFocus|Begin] Run AF when filter changed, L changed to H, exposure 2.0s Bin2, temperature -3.5℃
2023/02/15 19:44:22 Find Focus Star
2023/02/15 19:44:27 Find Focus Star: detect and calculate star size 2.6 , EAF position 51843
2023/02/15 19:44:27 Find Focus Star: finding appropriate stars star size 2.6
2023/02/15 19:44:41 Find Focus Star: detect and calculate star size 7.6 , EAF position 51993
2023/02/15 19:44:41 Calculate V-Curve
2023/02/15 19:44:46 Calculate V-Curve: detect and calculate star size 7.4 , EAF position 51993
2023/02/15 19:44:52 Calculate V-Curve: detect and calculate star size 5.8 , EAF position 51963
2023/02/15 19:44:57 Calculate V-Curve: detect and calculate star size 4.6 , EAF position 51933
2023/02/15 19:45:03 Calculate V-Curve: detect and calculate star size 3.7 , EAF position 51903
2023/02/15 19:45:09 Calculate V-Curve: detect and calculate star size 3.0 , EAF position 51873
2023/02/15 19:45:14 Calculate V-Curve: detect and calculate star size 2.3 , EAF position 51843
2023/02/15 19:45:20 Calculate V-Curve: detect and calculate star size 2.8 , EAF position 51813
2023/02/15 19:45:26 Calculate V-Curve: detect and calculate star size 3.2 , EAF position 51783
2023/02/15 19:45:31 Calculate V-Curve: detect and calculate star size 3.7 , EAF position 51753
2023/02/15 19:45:37 Calculate V-Curve: detect and calculate star size 4.5 , EAF position 51723
2023/02/15 19:45:46 Find Focus Point
2023/02/15 19:45:51 Calculate Focus Point: detect and calculate star size 3.3 , EAF position 51888
2023/02/15 19:45:57 Calculate Focus Point: detect and calculate star size 2.9 , EAF position 51873
2023/02/15 19:46:02 Calculate Focus Point: detect and calculate star size 2.5 , EAF position 51858
2023/02/15 19:46:08 Calculate Focus Point: detect and calculate star size 2.5 , EAF position 51843
2023/02/15 19:46:14 Calculate Focus Point: detect and calculate star size 2.3 , EAF position 51828
2023/02/15 19:46:14 Auto focus succeeded, the focused position is 51828
2023/02/15 19:46:14 [AutoFocus|End] Auto focus succeeded
2023/02/15 19:46:14 Exposure 600.0s image 1#
2023/02/15 19:49:07 Stop Autorun Manually
2023/02/15 19:49:08 [Autorun|End] Pause Autorun
Log disabled at 2023/02/15 19:49:08
Log enabled at 2023/02/15 19:56:27
2023/02/15 19:56:27 [Autorun|Begin] NGC1499 Start
2023/02/15 19:56:27 Target RA:4h3m47s DEC:+36°25'44"
2023/02/15 19:56:27 Shooting 20 light frames, exposure 600.0s Bin1
2023/02/15 19:56:27 Exposure 600.0s image 1#
2023/02/15 19:56:40 Stop Autorun Manually
2023/02/15 19:56:40 [Autorun|End] Pause Autorun
Log disabled at 2023/02/15 19:56:40
Log enabled at 2023/02/15 19:57:22
2023/02/15 19:57:22 [Autorun|Begin] NGC1499 Start
2023/02/15 19:57:22 Target RA:4h3m47s DEC:+36°25'44"
2023/02/15 19:57:22 Shooting 15 light frames, exposure 600.0s Bin1
2023/02/15 19:57:22 Exposure 600.0s image 1#
2023/02/15 20:07:27 [Autorun|End] Pause Autorun
2023/02/15 20:07:27 [Guide] Stop Looping and Guiding
2023/02/15 20:07:45 Mount GoTo Home POS
2023/02/15 20:07:45 Stop Tracking
2023/02/15 20:07:45 Shutdown ASIAIR
