If I have 2 scopes with cameras on them, can I create 2 instances of live stacker and connect each camera to their unique live stacker instances in Windows. And can I capture from both telescopes at the same time?
cmcacmca75 Hi, cmcacmca75! Yes, it does. You can try it. The same camera can only be opened by one application instance.
ASIStudio@ZWO Thank you, and I just wanted to make sure that it wasn't discouraged because ASIStudio can't guaranty the captures to be smooth (excluding PC performance limitations).
