I have had the ASIAir Pro and now the ASIAir Plus on two different mounts. The first mount was a SkyWatcher EGM-35 Pro. My current mount is the iOptron HEM44EC. With all these combinations, I've had issues where at some point or another during the night--usually following a meridian flip, but sometimes for reasons I can't explain--the ASI decides to plate solve to recenter the target. It will successfully plate solve, then decide it's off target, and issues a command to move. It then plate solves again, decides the target is off-center, and commands a new slew. This happens over and over again, until I catch it. I've attached a log from a session earlier this month.
The one thing that's been in common has been my camera--a Nikon D850 DSLR (48 MP). In the past, I thought I noticed that the ASIAir would command a shot, then another, but the next shot was identical to the last--even when focusing. In fact, when focusing, I know I have to wait for every other shot before I try a new setting. To test this hypothesis, using Subframe Selector in PixInsight, I started graphing the FIT files ASIAir saves to the USB versus the RAW files my camera stores locally. The RAW files graph as you'd expect, with random spike in PSF weight. The FIT files, however, graph in a pattern where almost every shot is followed by a shot with the same PSF weight. From that, it appears the ASIAir isn't saving every shot, but rather is saving the same shot twice. I've attached a PDF of a representative graph.
Now to my overall hypothesis. I think perhaps what is happening is that at some point the ASIAir commands a GOTO, then centers. It takes a shot to plate solve, and decides the target isn't centered, so it calculates a change and commands the mount to move. It takes another shot to plate solve, but instead of an updated photo, it's using the first photo. In that case, it calculates an even bigger change, and commands the mount to move. This time the shot the ASIAir plate solves is new, and definitely not on target, so it commands a move. It shoots, plate solves on a duplicate, calculates yet another erroneous move, commands a move, and so on.
The only way I can think of to test this hypothesis is with another camera to see if the issue is resolved. Unfortunately, I don't have another camera at my disposal.
Long post, but i have three questions:
- Are others having this same problem, and what camera are you using?
- Is my hypothesis reasonable?
- Would someone who does have both be willing to test it?
Thank you.
