Some important results.
After it showed a good performance on WoP with the lighter scopes, I thought of using the counterweight and testing.
So, for example, if CW was 2 kg plus 0.5kg shaft weight, "net" weight of scope would be 5.5kg.
I have found good results. With higher weight, WoP and EoP are now both good. Also, the dominant period is now 430 or so sec, with the 1100 sec period becoming less important.
The difference is quite a bit, from 0.69 down to 0.46. Notice that EoP guiding stays similar around 0.45 or so.
This is over 3 nights, so I dont think it is guiding or seeing related, but I will continue to monitor. So far so good.
So the WoP loading does something in the gearbox?
