ASIMount@ZWO
Hello, here are results with Redcat51, which is much shorter FL and much lighter.
WoP and EoP imaging times are 1-2 hours and roughly the same on each side.
Please note that I have tried to equalise guiding parameters as much as possible. So all cases are 1.2 sec exposure, hysterisis, Aggression 70%/80%. The only thing which cannot be truly equalised is min-move as, the guidescale for RC6 is 0.87" and for Redcat is 6.45". Minmove in RA is 0.07" and in Redcat is 0.32".
So I would rather focus on the difference between EoP and WoP guiding in RA for a given target rather than the actual numbers.
As you can see
The guiding on both sides of meridian for Redcat is almost the same for a given target (green). Whereas for RC6, the difference is much more (highlighted in red)
Even for Redcat, there is still the 1100 sec harmonic, but it is much smaller, and can be easily guided out. The main harmonic is 430 sec or so (green). This is similar to what can be seen even for the RC6 when EoP.
Only in RC6, when WoP, the primary period is 1100 sec (red).
So is the weight of the RC6, or some weight distribution is causing this behaviour?
If this is correct, then the good news is that it can possibly be corrected with a counterweight - I will test and see.
The bad news - does this mean the weight limit of 13kg without counterweight and "no balance" feature of AM5 is restricted only to smaller and lighter scopes?
Request views please.
