Mirrorgirl it does go on but as soon as i plug it into computer and put cooler on it stops working
The fan will turn on when you first connect the camera to power, but not yet connected software to the camera. So the first part of the behavior that you saw is correct, and moreover shows you have enough power feeding the camera and the fan is working.
Now, once you connect the camera to a program, the cooler and the fan in the camera will turn off (again, same as what you observed), since the cooler state of the program will also be off.
The fan should only then turn on if you asked for it to turn on and the cooler is actually active. If the cooler is not actually active, the ZWO cameras (at least an ASI2600MM or MC) will also turn the fan off.
So, you might check the setpoint temperature of your camera and see if it is say, 10ºC or so below the room temperature, after manking sure you have turned on the cooler in your program.
I just tried this with an ASI2600MM connected to a Mac Studio running ASICap in ASIStudio v1.8.1 and can confirm that it behaves as I described above.
Connected camera (with power) to computer, the fan in the camera runs.
Connected ASICap v2.8.1 to the camera, and fan stops.
Open the Control (icon with blue circle and three dots -- who would have thunk it represents "More control"!) , tap on the TEMP tab, turn on the Turn On Cooler button, and set Target Temp. to 3ºC and voila, the fan comes on after a second of two of latency.
Switched off the "Turn On Cooler" button, and fan goes off.
