johnpd Thank you for the help. I guess the USB hub is what I'll need to do. I did get it to recognize with ASI Cap- that works well. I did then try with the AIRAir and it worked. So not sure why switching from one camera to another didn't work. But I can live with that.
rrosenberg8 I had hoped that problem requiring a hub would nave been fixed in v2. I am still sitting on v1.9. JohnD
rrosenberg8 An inexpensive USB hub works great and also allows another USB drive to be attached. I hasn’t needed external power either.
roialmog if you do resolve the issue - please post back here how it was resolved.
Hi, will there be support for ALT-Az mounts in a future release?
Any chance of including the possibillity for enabling remote access on Asiair?That would be awesome.
larkinsen What you mean with "remote access"? What kind of functionality? Asking this because the ASIAIR app is actually a remote access interface to software running in the red box of ASIAIR. Obviously you mean something else?
Corsair I have an iPad Pro from 2018. I was advised to update the iOS which I did but due to the weather I haven't yet had the chance to see if that did the trick. Honestly the iOS wasn't that out of date (16.x) so if that was the issue, well shame on ZWO for poor coding.
RoscoeD when you do, if the issue still occurs, take screenshots.
Although isn't setting up a Plan something you can test while indoors?
Corsair Yes, but it's all packed away and haven't had the time to dig it back out to test it.
Are there any plans to add the meridian flip to the Live stacking mode?
Leo39 Sorry to drag out this older post of yours. I am having the same problem with FW 2.1.4 11.06. It seems there was never any follow up. Did you eventually solve the problem? I also just posted a separate new thread about this missing angular deviation detection step.
Leo39 I do have the exact same issue now after the last update. Did you find a solution?
