Hello
roialmog
In your screen shot (the 2nd picture) you will see that ZWO is giving you an E-Mail-Address where to contact when you should have problems with your device!
Guess that is the best solution!
Else there is a small button ( RESET ) on your ASIAIR+ device * the side where you power on/off the ASIAIR+* try to push that button " gently please " for 5-10 seconds ( remove also all attached devoices from your ASIAIR+ ) not sure if it will help, but I guess that is why the RESET button is there..
Else, try to remove all attached devices from your ASIAIR and reboot again..
Hope you will sort out the issue soon..
Good luck
Martin
