I've been having a recent issue, don't know what's causing it. Power on, send mount to home and it doesn't move (so it's been physically setup correctly, scope on top of mount, pointing at polaris, counterweight pointing perpendicular to ground at its altitude angle). Do all other preparations fine. Start a plan, takes first centering image, makes adjustment, then the adjustments start to get strange. By the third it's usually pointing somewhere else or toward the ground. Last session it actually caused my ota to hit my tripod leg and get stuck. Sometimes when I see strange gotos, I'll send to home and the scope is 90 degrees west or left of the mount as if it's set its own home position mid use, despite home position being correct at the start of the session. This has happened with two different manufacturer mounts (gem28 and azgti). What could be causing this? Location is set correct. This has happened with my asiair pro, mini and plus. Never happened once when I was using a firmware prior to 10.47 and prior to app version 2.0. Due to the many problems with the latest app version and firmware I'm actually using v1.9 beta app and firmware 10.40 on my mini, it still happened even then, something is very wrong with the software to mount communication.
