Can ZWO EAF fit the Orion EON 110mm ED APO (11:1) hybrid-drive focuser.
xmj0001 I did not find this focuser on the supported list, maybe you can check the documentation to see if it's compatible https://www.yuque.com/zwopkb/hardware/eaf-support-list#28d4f836ec18ffe338fac4b58fe61b1a_h1_12
We appreciate it if you can share the result with us, and we will add it to the list.
Tech@ZWO Is The Orion EON 110 ED APO (11:1) hybrid-drive focuser the same as the Crayford manual focuser that mounts the Omegon Apochromatic RefractorPro APO AP 110/660 ED Carbon listed in this support guide. Also is this the same as https://primalucelabusa.com/primalucelab-2-7-hybrid-drive-focuser-for-refractors.html. The current instructions require the removal of the central lock screw and a allen screw, with the rethreading of the allen screw and 2 new threads created I'm looking into creating a custom bracket but it should work.
This is what the bottom of the focuser looks like
