294MM Pro - advice or input please
1) moisture on the sensor ?
2) replace or microwave the desiccant tabs ?
3) install the ZWO dew heater in front of the sensor ?
4) too much moisture in the air " 95% + humidity in my location tonight
This image ( M81 Bodes ) is with an Optolong 2" Luminance filter ( brand new - used once ) - 300s, gain 120, sensor temperature 32 degrees Fahrenheit
thank you in advance
