scopesnc Is it not possible to use the ASIAIR for this?
Not only is it possible, the fact that you can now focus the telescope from the dark indoors can be a great help. You still have to tune the etalons out in the blazing Sun, but fine focusing can be done remotely.
ASIAIR did not implement solar guiding, so the mount has to be left unguided, unless you add a solar guider like this one: https://www.sciencecenter.net/hutech/Hinode-sg/index.htm (IMHO, worth its weight in gold.) You can still connect and issue GOTO from the ASIAIR to the mount, but guiding in this case is through the mount's ST4 port.
Remember that you also cannot polar align in the daytime using an ASIAIR; so it is best to leave your polar aligned tripod outdoors until morning. Or, at least mark the locations of the tripod legs on the ground.
The reason you don't see much discussion of solar is that ASIAIR has nothing specific for solar. (Note: no money to be made, since they don't OEM any product for solar work either).
