• ASI Mount
  • Getting the best performance from my AM5
Kevin_A
Hey Kevin, thanks a lot for taking the time to share your info.
I will definitely have to give it another try and maybe without the counterweight.
I initial thought that adding just a 1kg counterweight would help with the guiding, as it should make the mount more stable.
I understand, from all your help and answers on this forum, that you know your way around the AM5 and the harmonic mounts in general as Chen also does.
If you allow me, I would like unfortunately to bother a little more 🙂 and ask a tiny bit more for help..
I have calculated the slope based on my chart, by using the steepest slope that Chen suggests according to my graph (even if is possible that is not the steepest, as it might not be represented in the chart by ZWO).
I mainly have 2 questions:
  1. Is there a way to measure the full PE curve of my mount, maybe with PHD2 guiding, and how long would it take to complete a full turn (for a 288 seconds period mount) ?
  2. And once I have the slope, where do I go from there? Meaning how do I select the settings from the guiding (Aggression, MnMo, MaxRA/MaxDEC) ?
Thanks again.
And of course if anybody else has any suggestions and advice you are more than welcome to add them !
I will be happy to try anything to make sure that I get some repeatable setting and guiding.
Clear Skies !
Gagan
    Gagan you need to run the mount with guiding turned off in phd2. You need to run at least double the period of the mount and even 4 times will verify accuracy. Make sure polar alignment is good first. Once you have that data you can see where the worst slope is.
      4 days later
      3 months later
      Hi everyone! I am new with AM5 and I found your discussion about guiding numbers very instructive, but still I have difficulty to fully understand these settings. So, can you please suggest me how should I set my guiding numbers, considering my mount PE test report graphic? I am using two different scopes, a SkyWatcher 200/1000 PDS and an Askar 300 (60/300mm), and a 50mm guide scope with ASI120 MC-S as guiding camera. I used mostly the standard numbers in the beginning but unfortunately, after the last ASIAIR firmware update, I failed to guide anymore. I struggle a while but still no more consistent guiding. Thank you in advance!
        Convair firstly…. Use a mono guide camera not a colour one. Next set your calibration step size to about 1350ms, durations to about 450ms on Ra and Dec using either 0.5s or 1s guide exposures. Try 1s first as you get better guide star SNR with that longer exposure. The camera gain needs to be high enough that multistar guiding uses and finds more than 8 guide stars, 12 preferably. Make sure the guide scope is well focussed and calibrate in the south near the meridian on the side you plan on imaging. I would upgrade your guide camera to either the 120mm mini or the 220mm mini. Your PE graph is quite good so it should be easily guided. Minmo should be set to 0.1px not 0.2px under the advanced tab, they call it trigger accuracy but it is really Minmo… I think it may be in the advanced tab under mount tab . Cheers!
          Kevin_A man, thank you! I´ll give it a try. I use to guide very smooth before ASIAIR last update, after that is almost a disaster. I really fight to have back my old guiding.
          Maybe someone can give some advice. I've had the AM5 for a year and its been fine with my wide field scopes (mainly Sharpstar 94EDPH) at 420mm FL. Back in March I added a Skywatcher Esprit 120ED (860mm FL) as the main scope (using Evoguide 50ED and ASI290MM mini as guider) using the 200mm Pier and HEQ5 tripod. I have had more variable guiding but have been able to shoot up to 300s subs and get several very nice images. Pointing at targets high in the sky yeilded worse guding but acceptable. Past couple of sessions though have had issues with an inability to even shoot 60s subs with guiding on at high targets. 8 out of 10 subs are unusable with sharp oscillations causing spikes or double stars. I thought at first it might be seeing related but the second session had good seeing conditions. No amount of playing with agression helps or recalibration on the target or calibrating South near the equator. Turning guiding off however yeilds pinpoint stars at 60s exp. As such I'm at a loss as the mount is clearly PAed OK and tracking OK but the guiding algorithm seems to be sending it haywire when it should be issuing very few corrections. I've tried my ASI120MM mini as well with no change in outcome. Also played with max Dec/RA durations between 350 and 1000 (normally I have Dec at 350 and RA at 500). Have tried 0.5s, 1s and 2s guide exp (normally use 1s) and no change. Agression between 25% and 50% no impact. Last session I ended up turning guiding on to get a Dither, then switched it off and shot unguided before rinse and repeat. Painful but at least I got useable luminance data. The weight of the scope fully loaded is 14kg so I have a 4.5kg CW and the ASIAIR Plus is running 2.1.1 (10.74). I have also found the centre of gravity of the scope and line this up with the middle of saddle. Everything is tight including the guidescope. I haven't upgraded the ASIAIR and not sure whether there is anything advantageous to doing so? I'm taking heart that the mount tracks well unguided....still any suggestions welcome as the images from the Esprit are beautiful but I need consistency from the guiding on the AM5.
            Scotty you need to update to the latest version of asiair 2.1.2 then go into the guiding advanced tab and make sure the trigger accuracy is set at 0.1px and not 0.2px. That trigger accuracy is Minmo.
              17 days later
              hi All, I've posted this separately, but this thread is much more popular, so re-posting here, too..
              I’ve bought am3 and was able to test once on a windy night with 2h clear window. I also forgot to secure the latitude adjustment locks but still excluding big spikes at the beginning and end of session I got around 1” RMS. The load is c.a. 4.5 kg (mak127 plus 189fl 50mm guide scope).
              I’ve been reading posts about periodic error and started drawing lines on my report and calculated steepest slope error at c.a. 0.22 arcsec/sec. I’m attaching my report - I’m worried about the spikes on the graph - should I be?
                Kevin_A Phew! thanks for reply! I'm still waiting for clear skies to test it out and started worrying.
                Kevin_A Hi Kevin - just to report back that after the upgrade the AM5 has been very good with the Esprit 120ED over the couple of sessions that the clouds have parted. Thanks kindly.
                Kevin_A @w7ay
                I actually used WebPlotDigitizer https://automeris.io/ and I got values that concern me.. even 1.91 arsec/sec (@267.34 degree) and 1.64 arcsec /sec (@264.9 degree) as described in fbitto
                I plotted all values, extracted to xls and multiplied degrees (x axis) by 240 to get to seconds (I have AM3 mount). Below are some of the worst numbers.. Am I missing something?
                does this mean my mount is terrible? should I use 1.91 arsec/sec as a number to provide corrections against?
                Here's my chart with PE again:
                [EDIT] I've since then amended the alignment of the points in WebPlotDigitizer and I've got now worst number of 0.60 arcsec/sec and -0.75 arcsec/sec. Does the length of the slope matter? e.g. -0.75 slope lasts for 0.36 second and 0.60 lasts for 0.43 second. If I got the math that is..
                and here's the complete chart with derivative
                  wookash
                  I have stopped commenting on ZWO mounts, but since this post is directly addressed to me, and I particularly liked your idea of showing the full derivative graph (last image, which shows the 90º phase relationship between sine and cosine [its derivative]), I will make some quick comments on points that are still being ignored on the forums. Not directly related to ZWO mount glitches, but autoguing in general.
                  (I have no dog in this hunt. I am current getting 0.25" total RMS type guiding with an RST-135E (RainbowAstro and Hobym were the first to use strain wave gears, from Harmonic Drive, LLC), with an FMA180-pro as the guide scope, ASI678MM as the guide camera at 2 FPS update rate and camera gain of 27 dB, with a Baader Neodymium filter. I use RA and declination steps sizes that are barely sufficient to handle my mount's PE derivative, to keep any centroid computing error from making more error than neccessary, and I keep the loop gain really low. )
                  That 0.6 arc sec per second (and probably a little worse at places that ZWO won't show the numbers) is going to determine the minimum guide pulse that you will need to handle the worse time.
                  Remember (most people miss this part about guiding, even people who do implementations!) that when you take a guide exposure, you do not get the position of the star. What you get is a streak on your guide frame, corresponding to a guide star as it moves during the exposure. If you use a 0.5 second exposure, and the derivative is 0.6 arc sec per second, the guide star has moved 0.3 arc second during the exposure. I.e., if you look carefully, in the worst case, a guide star is a streak of 0.3 arc second long, not a single point of light. And (this is the expecially bad part), PHD2 has no idea which endpoint of the streak was from 0.5 second ago, and which is the most current endpoint (!!!) -- this can be improved by better algorithms that are based on the sawtooth, which is a dynamic estimate of a star position. The best it can do is to estimate the centroid of the streak . I.e., we are not estimating the centroid of a nicely formed star, but of a short line that in your worst case, is a line that is 0.3 arc second long. This is going to affect how well you can guide. In your case, I would expect guide glitches, even when there is no wind, of the order of 0.3 arc seconds when using 0.5 second (2FPS) guide update rate, and 0.6" when using 1 second guide update rate (1FPS). (This is why you need to use high guide frame rates with mounts that have high first derivative of the PE curve.)
                  Another thing to remember is that the places where you are going to get spikey errors will move 15 minutes from one night to another. So when you are taking notes to find out more about your mount, you need to take this into consideration. The relationship of periodic errors of the mount motor and gears is relative to your mount's hour angle, not to the sky's right ascension angle. I.e., when you take maeasurements, it is relative to where the mount is pointed to relative to the meridian. Each night, the meridian moved 15 minutes in right ascension.
                  To be objective, you also need to measure at the celestial equator. When you are near the pole, each arc second of the gear error will move the guide star by a smaller number of pixels compared to the star at the equator.
                  A final comment on the relationship between the worst case slope (your 0.6"/sec and the longest guide pulse duration. The reason you want to keep the pulse duration as short as possible is because of all the centroid estimation errors. With a nice Renishaw encoder, the feedback is very well controlled. With autoguiding (basically using the stars as your encoder) you need to estimate the star location (centroid) when there is atmospheric turbulence, stars not a single point, etc, and in the ASIAIR, case, poor centroid algorithms. You cannot keep these errors from moving the mount when they should not be, but you can limit how much it moves by using the max pulse duration settings. The centroid estimation errors will be different from one frame to another. This causes the guide algorithm to "overcorrect" in the opposite direction after the original centroid error. And you end up with an oscillatory motion if the loop gain is set too high. By setting the max pulse durations, you are telling the autoguider -- do not ever move the mount by this amount, no matter what centroid estimation tells you, because it is not an error that is produced by my mount. Basically, you are limiting the harm from centroid estimation error.
                  I.e., you choose 2 FPS vs 1 FPS to counter the worse case first derivative of the PE curve, and you set the max pulse durations to limit the error from centroid errors. Each setting solves a different problem (please let this sink in), even though both problems are ultimately tracable to the first derivative of the PE curve.
                    w7ay
                    Thank you, Chen!
                    So, assuming 0.6” slope and 0,5sec exposures I will need to start from 150-200ms max RA duration and work from there?
                    What about min move (in phd2)? Shall I set it to 0.1px or rather keep at 0.2px? My guide scope image scale is 3.16 arcsec/px
                    What kind of RMS should I expect?
                    I read most of the posts here and noticed you’ve mentioned AzGti a couple of times. It’s actually my current mount. It was interesting to see you’re comparing it to ZWO harmonic drives. I was not aware of this ratio (that gear mount 1/3 of the price of harmonic drive will perform the same). Still, I expected better guiding than with my AzGti and still hope to achieve it .. but for this I need good weather.
                    • w7ay replied to this.
                      wookash So, assuming 0.6” slope and 0,5sec exposures I will need to start from 150-200ms max RA duration and work from there?
                      Sorry. I do not answer questions on settings for ZWO mounts.
                        wookash use 0.1px as it will be better than 0.2px minmo using 0.5s guide exposures. You have to remember that these mounts are not meant to be great precision mounts, but meant to be very portable good mounts.
                        Use the mount and test it and if you do not get under 0.7rms consistently as zwo advertises then return it or contact them to get it fixed so it does meet spec.
                          Kevin_A thanks. I don't have good weather recently but it looks like I should be able to get between 0.5-0.7 RMS, still need to test it for a longer period and with better visibility
