Kevin_A I am wondering if my fan on the 2600mc pro has a bit of vibration as it is a bit more rougher than my 533 and 183 smaller cameras….
Just change the setpoint temperature so that the fan is just off, to measure a reference star size. Then change the setpoint so the fan just turns on (this way, off and on only changes dark current noise minimally just in case it affects the FWHM calculations).
Take a few exposures with the fan off and a few with it on and take averages.
Send the images to some program (like AstroPixelProcessor) that analyses the FWHM.
Do not trust the HFD numbers from ASIAIR - it is not accurate, and depends on the background light level -- you may have noticed that ASIAIR HFD (when "auto-focusing" and with Star Detect tool) gives better numbers before it gets full dark out of astronomical twilight. Well, just another of ASIAIR's bugs.
See if the FWHM changes from fan off to fan on.
Unfortunately, Noctua does not make the larger (thicker) fans used in the larger ZWO cameras (2600, 6200) etc. They do make one that will fit the older cooled ASI183. Otherwise, it is a high quality European fan, with integrated anti-vibration pads instead of external grommets.
For now, the best you can do is to add some rubber grommets (which should have been there in the first place), or switch camera manufacturer (I recently bought the QHY version of the cooled IMX533 sensor instead of the ZWO cooled ASI533).
