Kevin_A Zwo says the 290 is 30% better guiding over the 120mm mini…
ASI290MM Mini has been replaced by the ASI220MM Mini, Kevin.
Substantially larger FOV which is a good thing for multi-star centroids, lower Read Noise, and higher QE. Unfortunately, it is sensitive in the near-IR region, so if the guide scope is not close to an APO, you may need a IR-cut filter to go with it to reduce star bloat.
Also need a longish focal length guide scope, but not as bad as the ASI174, though. Other weak point is the shallow well -- so need to pick camera gain carefully for multi-star centroiding.
I got one, but not impressed. So, I am back to the ASI178MM for guiding.
