w7ay
Hi Chen
Thanks a lot for your reply
The 0.8arcsec/sec I was talking about was just an example. The max value I have on that tiny part of the whole measurement is 0,21,what lies within the average slope most people have with these mounts (0.17 to 0.35 from what I read ), maybe a little bit on the good side. The only difference I see is that we often see large Max PE amplitude on previous mounts with 432 period, and this one is quite reduced, like the one posted above, also a 288 period one. But as you say, we don't really care as long as we are guiding... And looking at the graph, we can see that for let's say at least 85% of the time, it's under 0.1. Some frames might be devoted to dustbin, but that's not catastrophic neither.
I asked zwo the complete dataset. As it has been measured, it must be stored somewhere. Will they acces to my request...? As you say, a conservative approach would be to double the max value we get from our measurement.
Anyway, IMHO, these mounts are really devoted to travel, easy setup, and short focal lengths. So the resolution of these short FL setups, associated with typical pixel sizes of 3.7u, will be forgiving.
But it's a nonsense to me when I see C11s on it š³.
As long as you can't take your scope in a bag pack, or cabin luggage, what is the point to have a compact mount to put a huge tube on it? When buying these mounts, we pay for compactness, easy setup, not for accuracy. I have a feeling that, with typical sensor chips, anything above 600/700 mm is not adequate with these harmonic mounts, they are not made for that.
I actually guide with an OagL and a 178mm also. As my focal length is quite short (400mm), I don't really have difficulties to get several guide stars, so I should be able to test your recommendations. ( as soon as the clouds will get away, and the real night will be back..).
And Finally, I don't use ASIAIR. I always put minipc's on my mounts ( mele Q3), because I can't live without NINA. So this shouldn't be an issue to test 0,25x guiding rates.
Thanks a lot for all the extraordinary stuff you posted here, I learned a lot.
Ben
