• ASI Mount
  • Getting the best performance from my AM5
w7ay Sorry it took me some time to respond as I was offline for a couple days. Yes I am in the EU and the mount is still under the legal 2-yr warranty period here. I don't think I've gotten to the point where I'd need to sue - that would probably take 10 years to conclude and cost a fortune in lawyer's fees, where I live, haha.
Update from ZWO: they still haven't agreed to a refund/repair/return but instead have shared a beta version of the ASIAIR iOS app and asked me to test guiding with this beta and the min_move at 0.2 (so I'm assuming that in the beta they would allow me to set that parameter which is not configurable in the GA app). We haven't had clear skies in weeks here and I'm now waiting for the clouds to be gone so I can test what they asked. Is this an implicit admission that the 2.9s spike might be SW related? You mentioned that hypothesis in one of your earlier posts.... To be followed!
    PS: I also bought a counter-weight shaft and will try to attach a small CW to the mount to see if that alleviates the oscillations. I don't have a solid theory to support that, but I guess it's a not-so-costly experiment I think is worth trying.
    Jan75 min_move at 0.2
    That simply means that ASIAIR will not issue any correction pulses until the error has exceeded 0.2" (really a bad idea with mounts that have large PE slope to start with).
    I can't see offhand how it is going to help the 2.9s spike case, where your spike's amplitude is already larger than 0.2". Are they really studying your problem, or simply conflating your problem with some one else's problem?
    Don't completely balance it, though. You will find that a slight imbalance with actually help the meshing of the gears; even though a strain wave gear already have lots of teeth that are meshed -- that is why they have so much torque and so little backlash.
    But certainly does not hurt to try.
    Good luck.
      Jan75 Thank you for your patience. For now you haven't had chance to check, we recieved several feedback about the beta version of ASIAIR that their RA ocillation has disappeared.
        Folks, I just got my AM5, not installed, yet.
        I've read through this thread , hope I understood the issue and the possible "fixes", i.e. settings in PHD2 (not using ASIAIR).
        From my graph, I calculate about 0.35"/sec. Now from what I've seen here, that seems to be on the very high side?
        Could anyone please confirm that I'm doing it right?
        BTW: I don't think I've read that (maybe missed it), but isn't peak-to-peak in those graphs exactly 4.3cm for 430 seconds?
        Thanks!
        Chris
          CHriss just try it out, it is a 432s period so that is good but I think your estimation is a bit high.
          Calculation based on my PE curve yields 0.42"/s as the maximum slope (at least for the section depicted on the report) so your 0.35" is not surprising to me, albeit admittedly high.
          Based on ZWO's own examples (see below), the "relatively large PE" case is at 0.21"/s so it's probably safe to say that that's already considered by ZWO as being a rather poor performance:
            ASIMount@ZWO I'm curious and hopeful, however I guess it would help if you guys could elaborate on what was changed in the beta version of the app (and not in Asiair or AM5 firmware) that makes you believe will solve the 2.9s spectral spike (i.e. oscillation occurring every 2.9s). Can you provide some details?
            w7ay I can't see offhand how it is going to help the 2.9s spike case, where your spike's amplitude is already larger than 0.2". Are they really studying your problem, or simply conflating your problem with some one else's problem?
            Not sure either. I sent ZWO Support an email with the question, I'll let you know if they respond. I'm glad to see that they are monitoring this forum, too.
            Kevin_A
            Hi,
            Long time huh!!..🙂
            I already calculate it, Its = 0.141"/sec.
            So, Could you tell me please what to do with this number? Rather than I search all this long thread 🙂
            I am using PHD2. WO scope FL=200, ASI290MM mini.
            Thanks
              MrAstro calibration steps based on your equipment would be around 900ms.
              Set your aggressions at 35-40% and max durations around 350-500ms using 1s exposures. Use 0.5X guide rate. Bump up the guide camera gain to around 200-300 depending on your skies, calibrate in the south near the meridian at the side you are imaging in to start and go from there. No mounts are the same so this is just a starting set of guestimates that should have you in the right area. Cheers!
                Kevin_A
                Thanks..
                Sure mounts are deferent but I thought many thread participants have calculated the max error from the graph like me.
                After that I can not get the real purpose of doing that 🙂 if its gust estimating settings values we can estimate without doing calculations I suppose ! Or it gives hints ?
                Thanks.
                  MrAstro each mount is different. That graph that everybody gets with their mount is not representative of the complete full period length, it is just the max PE, not max slope necessarily, so all calculations made will not be exact… so you just use it numbers to calculate as a baseline settings average. From there you try less aggressions and less durations. If that does not help then start at the baseline and try more durration etc. That is why the baseline is a good guess to start at and a place to start based on the part of the period graph you do have numbers to calculate from.
                    @MrAstro Kevin_A From there you try less aggressions and less durations.
                    Actually longer "max durations," since the true worst case slope is probably steeper than the one found from the expanded graph on that piece of paper.
                    Just increase the max duration if you see a string of flat-topped correction pulses in a row on the guide graph (indicating that the pulses are not long enough to correct), if the flat topping is not caused by wind gusts.
                    You probably don't want to correct for wind gusts, since the guiding will undershoot the opposite direction after the gust. And if aggressiveness is set too high, leads to oscillations.
                    The worst case slope in that graph is simply the best that you can expect from your particular sample of the mount.
                    So the first night with the AM5 was pretty disappointing.
                    Played with the settings for hours, there were times where guiding was running between 0.5 and 0.6 arcsec but only for short time periods. Total RMS never was under 0.69 and usually in the mid 70's.
                    My 15 year old NEQ-6 was WAY better than that.
                    Of course this was one night night only. I really hope for some "magic improvement" settings.
                    If not......AM5 equals to very expensive eye candy, not suitable for serious astrophotography. Or certainly limited to shorter focal lengths and exposure times.
                    And there was one thing, no idea what happened. The scope was pointing near the zenith. Has anyone seen sth like that?
                      CHriss what did the star mass look like? Was it repeating like that? Sooo many variables can cause issues. Hard to say. Looks to me that the max durations were not enough to recover as I see a flat comb shape but huge over corrections from something too.
                        Kevin_A ... I see a flat comb shape but huge over corrections from something too.
                        Hmmm, where did you see that, Kevin? I was looking for correction pulses, and did not find any (my browser may not be showing blue that prominently either) -- I was about to ask him to turn on the correction pulses the next time he see this oscillation. What I had been calling a "comb" refers to a comb of saturated correction pulses (i.e., max duration pulses sent in a long sequence and still not sufficient to correct the mount's slope error), and not to a constant amplitude oscillation of the RA error itself.
                        @CHriss
                        When you ask for recommendations from folks who are not at your computer, please include all autoguiding information that you can. I suspect, for example that your problem comes from an RA Aggressiveness setting (loop gain) that is set too high, and that caused the RA pulses to alternate in sign (i.e., oscillation caused by the autoguider software, and not the mount). However, you did not show the aggressiveness setting for RA, nor turned on correction pulses on your chart -- so there is no way we can tell with even 1% certainty what is happening, except that we see abnormal rapid oscillations (that is usually associated with applying too long a pulse to the mount, together with aggressive numbers -- basically the loop gain, if you are familiar with feedback loops -- that are too large). Actually, I am also surmising that the oscillations are rapid -- I was looking for the abscissa scale and didn't find that either.
                        The other important thing -- you will find that in general, strain wave gear mount autoguides about as well as a worm gear mount that is 1/3 the price of the strain wave mount. It is just the nature of the beast -- the market for strain wave gears are the people who are willing to pay the extra for portability (no need to lug around heavy counterweights, or for that matter the weight of the mount), and no need to worry about balancing (especially not having to worry about "third axis" balancing). Part of the market is for old folks like me who can't handle weights, even though I don't take any telescope out of the home anymore.
                        If you had bought these mounts on the premise (or promise) that they can autoguide as well as worm geared mounts, that is false advertising, and you should remedy that.
                        I have been using strain wave geared mounts for some 4 years now and still slowing trying to get them to work to my satisfaction (part of it due to my OCD -- most people would be happy with a 0.5" error). At least I have gotten mine to now guide to the 0.35" region by applying everything that I know about the behavior of these mounts, and the autoguiding software.
                        So, patience is required to learn your mount (each mount is so different from another one from the same manufacturer) that you can't just depend on what other people use to tune their autoguiding parameters.
                        There is a large variance in the sample you get (luck of the draw). Just because I can get 0.35" from my RST-135 does not mean that a different owner can get the same performance -- his/hers might be better, or it might be worse. But it appears like ZWO mounts have much larger variance (bigger lottery) from one sample to another.
                        You need to be patient (just like other aspects of this hobby) and slowly learn your own mount. Or simply buy a nice traditional mount. An Avalon M-zero for example will wipe the floor with these strain wave mounts when it comes to configurability and autoguiding performance.
                          Kevin_A #p69123 Hmmm, where did you see that, Kevin?
                          Oh, I see it now! My apologies. (I had to magnify and altered colors. 75 year od eyes that went through cataract surgery :-)
                          The pulses are indeed maxed out, but only after the oscillation has started. Since the amplitude of the oscillation are large (12 arcsecond region), any pulse durations would naturally be maxed out when trying to correct it.
                          But there is a latency too. Notice that it takes a couple of pulses before the oscillation changes sign again.
                          (With digital feedback loops, latency is a killer when it comes to introducing oscillations -- kinda like phase error in analog feedback loops.)
                          Looks like it takes three pulses to correct 12 arcseconds. Assuming those are 1 second pulses, each pulse is some 4 or so arcseconds (0.5x sidereal rate would be 7.5 arc seconds). Thus Max RA durations appears to be large.
                          @CHriss
                          Check your RA aggressiveness setting. Start at 0.15 (15% in ASIAIR) and only increase it slowly (and try not to increase it to more than 0.5) only when there is insufficient correction.
                          Are you using a Max RA duration of more than 1000 ms or a guide exposure that is longer than 1 second? The pulses appears to indicate that you perhaps did.
                          If so, start at a Max RA Duration of 100 ms. Increase it only if you see long combs of the correction pulses, and the RA is slowly creeping off the chart.
                          Then make sure that you are using guide exposures of 0.5 seconds (and checking that your guide camera can keep up with a 2 FPS frame rate). That will make corrections more rapid. That implies that you will need to use multi-star guiding (or the "seeing" will eat you alive).
                          However, a 0.5 second guide exposure may mean that you need to upgrade your guide scope to get solidly a dozen stars when picking the multiple stars.
                          If you are happy with a 1" type guiding, a 1 second guide exposure should be sufficient -- but that will still require you to use multi-star guiding with at least 6 stars.
                          This is the onset of the oscillations:
                          There don't seem to be anything that stands out.
                          But please check your RA aggressiveness.
                            Sorry folks, I didn't intend to confuse you with that oscillating example. It was only for a short period and didn't happen before or after again. I probably should have pointed this out more clearly.
                            See a much better example below, as you can see from star mass and SNR seeing wasn't good.
                            The guiding generally wasn't bad, though. I just had expected it to be much "flatter" or smoother with the AM5.
                            As I've said, only one night, hopefully not a "typical" performance for my new AM5.
