OK, just tested the FPS.
I currently have the 4th generation (Chinese processor, ASIAIR "plus") in my box outdoors.  Ethernet connected.
Two ASIAIR clients connected to the ASIAIR.  One is a 12.9" iPad opened to the Guiding window., watching the FPS number  The second client is either an IPhone 12 Mini or the ASIAIR app running in a Mac Studio that is running the iOS emulator.  (I don't really use the iPhone 12 mini as a phone -- I still use a flip phone -- but as a small form factor iOS device, since Apple has discontinued the iPod touch.)  The Mac is connected to the same Ethernet switch that the ASIAIR device is connected to (so packets don't even pass through my router), while the iPhone mini is connected through WiFi of the eero mesh network.
With either of the clients, I can switch windows, change the image scale, and so on, and the guiding FPS stays perfectly fixed at 2.0 (with 0.5 second guide exposure).
However, when I capture an image on the main camera (a dummy ASI183MM with a CS lens on it), the guiding FPS stutters down to 1.8 and 1.9 FPS while the ASIAIR device is uploading a new image to one of the clients.
This is a screenshot of the guide window at the time the FPS dropped to 1.8 FPS. Notice there is no glitch in the guide graph, though.  Not quite out of astronomical twilight yet, so I had to keep the gain low (13.6 dB) to keep the background from a whiteout.  But the "seeing" appears good from the guide RMS error numbers, even though the transparency is terrible, if you believe the satellite picture from WunderGround.com.
So, either guiding is fubar, or the one estimating the FPS is fubar in ASIAIR.
(This is one of the reasons I have converted an old M1 Mac Mini for 12V operation -- this is in preparation for running INDIGO in it, instead of running INDIGO Sky in a Raspberry Pi 4.  The simple processors just don't have the horsepower I need -- who knows how much processor I need for my guide algorithm :-) 12x faster on multi-core Geekbench 5, and 100x faster with 32-bit floating point arithmetic:
https://www.cpu-monkey.com/en/compare_cpu-apple_m1-vs-raspberry_pi_4_b_broadcom_bcm2711
