• ASI Mount
  • Getting the best performance from my AM5
w7ay the pulses in log viewer are there and happen right at the middle of the peak so it is working it seems… they are just not being shown on the asiair graph. I did find out why 2 of my older asiair pros are crappy… their minmo is 0.2 vs my asiair plus at 0.1. Same firmware update.
Weird but now I know why 2 rigs are good and 2 are bad.
    Kevin_A their minmo is 0.2
    Yep, that will definitely be one huge step back. Not problem for me, but for people stuck with using ASIAIR (their own choice, so you can't really blame ZWO).
      w7ay I guess I could go back to using phd2 but I think I prefer imaging wirelessly from my couch. Haha. But when I build another house with a real observatory then I will go back to where I can decide and use my own settings. Winter is coming soon and I just can’t do cold anymore!
      I hope they fix their errors in the next update. I moved both asiair pro units to my widefield scopes so higher guiding numbers are less critical . I did try an OAG on my Askar FRA300 and since the scope delivers crisp stars at F5 and with my 533mc pro having a tiny sensor, i could get it deep towards the centre… it worked quite well when I pumped up the gain. I imaged all night at 0.5rms and under.
      Star quality definitely matters with this ecosystem.
        Kevin_A I guess I could go back to using phd2 but I think I prefer imaging wirelessly from my couch.
        You can do the same using this with a Raspberry Pi 4 (guess how I know :-):
        https://www.indigo-astronomy.org/indigo-sky.html
        From indoors, you can do rudimentary stuff (planetarium, mount control, camera control/scheduling, PHD2 guiding) just from any web browser (including on tablets), or use a full blown laptop on your couch with full blown components:
        https://www.indigo-astronomy.org/software.html
        The components are all packaged as a turn-key INDIGO "All-in-one" A1 if you are lucky enough to own a Mac:
        https://apps.apple.com/us/app/indigo-a1/id1617125771?mt=12
        https://www.cloudmakers.eu/a1/
        The second link has videos to how to do things like polar alignment, etc.
        (Notice that it collects no user data. Even if it does, it would go to a NATO and EU country, instead of to China.)
        If you prefer YouTube (comic book) documentation, Rumen Bogdanovski (one of the two principals) even has a YouTube video:
        https://www.youtube.com/watch?v=ko1Qjs9Zdes
        Rumen [https://bg.linkedin.com/in/rumenbogdanovski] owns one of the earliest AM5, by the way. Peter Polakovic, the other principal, is a MacOS nut -- he ordered his M1 Mac even before I did :-) For day work, one of them is an astrophysicist, and the other is a computer IT professional.
        Best of all, you can use better cameras, filter wheels, and image rotators than you can on an ASIAIR.
        Even better for a geek, since the INDIGO bus is completely open sourced, and documented (in fact, the only place I even found the documentation of communication protocol for the ZWO mounts was in INDIGO's documentation), you can add any of your own software (that is how I run my All-Sky camera nowadays, though a Raspberry Pi 4, and my own macOS program, using a no-longer used ASI294MC).
        https://github.com/indigo-astronomy/indigo
        Everything looks like devices on a networked bus. Add as many servers as you want to the bus, and access them from multiple clients.
        I have already 12-volt-modified a M1 Mac Mini (retired it as a desktop computer when I replaced it by the Mac Studio) to use as my outdoor server. Even if you buy an M1 Mini new from Apple, you can get it for $600, and it is orders of magnitude faster than an ASIAIR.
        So, you can go from just a single Raspberry Pi 4 and a tablet running a web browser, to a serious system where the sky is the limit. The upgrade path is already there today. Just add more processing power (more microcomputers, or simply a faster microcomputer) when you feel the need. (Oh, INDIGO can run any device that is supported by INDI -- you can even find humidity sensors. :-) All of your current ZWO devices will still work: I have tested ZWO EFW, EAF, cameras, etc. Just get a Raspberry Pi 4, download and burn an microSD IndigoSky Image, and start playing from just a web browser.
          w7ay I will keep it simple for now as i am getting consistant 0.5rms now that I tweaked a few things and put some better feet on my tc40 tripod, bigger guide scope, bumped up gain etc… but I think that is the best this mount can do and I am fine with that. It will never be an RST and as long as zwo stop making bonehead moves like increasing minmo for us strainwave dudes… then I will keep it simple for now. I just need the next update to reduce the minmo of the asiair pro for my older setups and add am5 guide rate adjustability and I will be happy.
          Cheers,
          Kevin
          Kevin_A Or just use remote desktop? I'm thinking of moving to a laptop based system too, just for the increased array of options in NINA/PHD2 vs. Asiair GUI.
          Also, one note, some progress on my side too. When I use BIN=1x1 on the guide cam (instead of the previously used BIN=2x2), the guiding results are in the realm of 0.4"-0.6" instead of 0.8"-1.0"+
          This is true both with a guide scope (60mm, 254mm FL, ASI ZWO 120MM) and with an OAG (ASI ZWO 220MM mini).
          Also, ZWO recommended that I open the AM5 case and check the belt tension; they asked me to adjust it by pushing the RA motor away to fasten the belt. I didn't do this because the method is quite rudimentary (unscrew, push, tighten - no easy way to measure the adjust movement)) and has no easy fallback.
          With 1x1 binning the performance is OK for my FL (1628 mm) so I think I'll just stick with it for now.
          I don't know if I will accomplish anything by posting this, but I have recently seen the same large RA oscillations in my AM5. Autorun (on M27) is where it cropped up. In complete desperation I went back to Preview and forced a calibration, and it stopped. This may have been a coincidence, but I thought that I would add the data point. I assume that there is a subtle (or not-so-subtle :/ ) bug in the guiding routine or the mount firmware.
          I've had the AM5 for almost a year now, and other than this recent development I've been completely satisfied with it.
          -Jon
            5 days later
            BrineyEye Would you please contact our support and provide your guiding log. It would help us to deal with your issuse. Thank you.
              5 days later
              BrineyEye and ASIMount@ZWO The guiding with ASIAIR appears to be sub-optimal to me because of the number of stars ASIAIR chooses to use for guiding. While I can visually see a number of stars, ASIAIR typically picks only 1 or 2, or starts by picking 5-6 then a few minutes later it's down to 1-2 again. With the AM5 requiring fast corrections, e.g. 0.5 s guide exposures, this means that you're chasing the seeing instead of correcting the mount tracking errors. Averaging the centroids over 10+ stars would more or less compensate for the seeing induced movements of every individual star. I've been having the hardest time trying to keep ASIAIR track more than 2 stars. This is where you can go from 0.4-0.6" guiding to 1.2"+ guiding with the same mount...
                Jan75 this isn't likely a function of the ASIAir. More than likely, it's the camera. I use an ASI178MM, and consistently get 10 to 12 guide stars on the Air. I also have an ASI290MM that gets about the same. My old 120MM would barely get 3 to 5.
                I agree about the camera - I upgraded to an ASI220MM and there was a significant difference. I also found that a larger aperture guidescope helps - I went from a WO 32mm to WO 50mm and saw a further improvement.
                A larger guide scope does wonders. Also, having a guide camera that has clean higher gains help. My 290 and 220 are great but my 120 is gain limited. Going from 30mm to 60mm guide scopes is a game changer. Another thing I have noticed with the AM5 is that the heavier scope setups guide much better than a very light scope. Maybe it is the bigger guide scope! My guiding is 0.7 with my Rokinon 135mm rig but down at 0.35 average with my big 648mm triplet.
                What is fundamental with multi-star guiding as far as guide scopes, is to have at least 20 guidable stars available in a guide frame.
                What this means is
                • a good guide scale. Oversampling will reduce the intensity of a star (and not be recognized), while undersampling will case centroids to be completely bogus. So it is more advantageous to oversample, as long as you make up the deficit.
                • a large sensor. A larger sensor will allow more area of the sky to be imaged, as long as the scope produces a flat enough field to handle the sensor. Just a larger sensor is not useful since any poorly shaped star that are away from the optical axis will do more harm than good. By the way, this has nothing to do with whether the scope is APO or not -- an APO objective converges three wavelengths of light to the same point; but with a refractor, those points will not be on the same sensor plane. You need a field flattener. (The is the biggest joke about the SeeStar. Notice that ZWO claims that it has an APO objective, but there is no flattener! None of the YouTube shills have pointed this out, by the way. ZWO always like making boneheaded design decisions like this -- just like putting emphasis with their mounts have small PE amplitude, while the real problem is the slope of the PE curve.)
                • at the same time, the sensor must not be so large that the guiding frame rate falls below 2 FPS.
                • the plate scale plus a large sensor may require a larger objective to get enough guidable stars (the 20+ that I mentioned earlier). You need enough photons.
                • good focus is imperative (my guide scopes all have an electronic focuser). A large blob of a star will spread the photons over too many pixels. The better focus, the more stars you will see in the guide frame.
                Why 20 guidable stars? This has to do with the distrrbution of star intensities, and the fact that ASIAIR uses SNR as the weighting function; including the brightest stars will cause the averaged centroid to just depend on the brightest one or two stars. Even when guiding with 12 stars, you will effectively be guiding using only 2 or 3 stars. So don't get fooled by ASIAIR. You need to increase the gain of the camera so that the first two or three stars are saturated. That will cause ASIAIR to use the remaining stars, which have a more even intensity distribution (thus more even SNR).
                Typically, an 10 dB increase in camera gain after attaining 12 stars will allow the brghtest stars to be rejected, but sometimes, you will need an additional 10 dB. ZWO uses a gain scale of 0.1 dB per gain unit, so be prepared to add a gain of 100 to 200 after being able to capture the first 12 stars.
                I cannot overemphasize this aspect since picking the first 12 brightest stars may only give you the equivalent of 2 or 3 stars guiding (definitely insufficient for typical "seeing").
                Getting a good centroid is only one aspect of the guding. It does make the difference between guiding to 0.35" (total RMS) vs guiding to 0.5". However, if your mount can only guide to 1" to start with, unless you are using ZWO's guide scope/ASI120 combo (really poor choice, I'm sorry for those who fell for it just because it is cheap), then improving your guide scope may not help.
                13 days later
                w7ay Hello Chen - Reading this post on how to calculate the min-move settings for the AM5:
                https://bbs.astronomy-imaging-camera.com/d/15989-getting-the-best-performance-from-my-am5/186
                I'm curious - I typically run the PHD2 Guiding Assistant for 3 or 4 minutes after calibrating PHD2 - and I let it suggest the min-move settings for my current mount (AP Mach-1 not the AM5), and I use those because they are from data gathered at the time I'm imaging. Curious if the Guiding Assistant will give good values for the AM5 (assuming they do for my Mach-1, which appears to be the case).
                Thanks,
                JD
                • w7ay replied to this.
                  johncdavis200
                  There are too many anomalies with this mount that I have given up giving advices on it. It is not just poor and noisy PE, but random anomalies.
                  If you can afford it, there are Strain Wave gear mounts that actually work consistently. While it will never guide as well as your Mach-1, my RST-135E can consistenly guide on the long term at 0.35" or better even with an ASIAIR, if there is no wind.
                  Because of the weight and age issues, I started a couple of years ago with two RST-135. I added an RST-135E recently, and liked it so much that I added yet another RST-135E. For shorter focal lengths (and planetary), I just let the Renishaw encoder do its thing, without autoguiding.
                  Sorry, but I am out of the business of figuring out all the ZWO mount anomalies.
                    2 months later
                    Believe it or not, I have read all 505 replies to this thread -- and am blown away at the usefulness of the information here. An all-inclusive summary should be written and "pinned" to the top of the thread if possible.
                    At any rate, I have two questions for my ASIAir & AM5 mount which I have yet to use due to weather:
                    1) What would be better -- a more-sensitive 50/200mm f/4 (WO Uniguide 50) or a SkyWatcher EvoGuide 50ED APO with a field flattener, but at a higher f/4.8? I heard what Chen said about misshapen stars contributing to multi-star guiding error. The EvoGuide + Flattener is almost $400 with tax, otherwise I wouldn't bother you with this question :-).
                    2) The camera would likely be an ASI290MM (the USB3 planetary version), but I am unsure. I am enticed to try near-IR guiding with the ASI220MM Mini, but I hesitate at its USB 2 interface, the large pixels, and the fact that it's not appreciably cheaper despite the non-Sony sensor. I'm also concerned about it being able to reliably meet the 2 fps rule un-binned (though the specs claim 14fps, maybe I shouldn't worry). The QHY678 is out, since I plan this to be an uber-portable rig with ASIAir, and there is no mono ASI678MM (what a dream that would be). The ASI178MM might be a good compromise, and it's 14-bit. Any guidance between the three?
                    Thanks in advance, and happy holidays!
                      mountainair the better star shape of the Skywatcher scope will be best as you can compensate for the slower glass f ratio by increasing the camera gain. I use both the 220 and 290mm mini cameras ( not the non mini version) and the 290 mini is not for sale anymore which is a shame. I think the sensors are fairly equal respectively but the smaller pixels on the 290 were slightly advantageous in my opinion. The 220 has been working fine for me and i like that the noise is very low past the HGC set point. I also looked at the Askar FMA180 Pro as an option too.
