Believe it or not, I have read all 505 replies to this thread -- and am blown away at the usefulness of the information here.  An all-inclusive summary should be written and "pinned" to the top of the thread if possible.
At any rate, I have two questions for my ASIAir & AM5 mount which I have yet to use due to weather:
1) What would be better -- a more-sensitive 50/200mm f/4 (WO Uniguide 50) or a SkyWatcher EvoGuide 50ED APO with a field flattener, but at a higher f/4.8?  I heard what Chen said about misshapen stars contributing to multi-star guiding error.  The EvoGuide + Flattener is almost $400 with tax, otherwise I wouldn't bother you with this question :-).
2) The camera would likely be an ASI290MM (the USB3 planetary version), but I am unsure.  I am enticed to try near-IR guiding with the ASI220MM Mini, but I hesitate at its USB 2 interface, the large pixels, and the fact that it's not appreciably cheaper despite the non-Sony sensor.  I'm also concerned about it being able to reliably meet the 2 fps rule un-binned (though the specs claim 14fps, maybe I shouldn't worry).  The QHY678 is out, since I plan this to be an uber-portable rig with ASIAir, and there is no mono ASI678MM (what a dream that would be).  The ASI178MM might be a good compromise, and it's 14-bit.  Any guidance between the three?
Thanks in advance, and happy holidays!
