I wonder if anyone around here uses the Askar 130PHQ with the AM5. I think the actual total weight would be more around 31 lbs, I forgot to add the doveplate and mounting rings. Should I go with an 11 lbs counterweight or would something less, around 6 or 7 lbs do?
If anyone has a similar setup with a payload between 30-32 lbs, I'd love to hear your experience with stability and guiding. I will try using the TC40 tripod with heavy rocks in the center pouch, but if it feels too light I will upgrade to a stronger tripod. Does anyone know of which aluminum tripods work with the AM5?
Thanks!
Jerry
