I am new to both ASIAir and Narrowband Astrophotography. ASIAir is an amazing product. I have gotten further in my astrophotography than ever before. I have never tried to do any Narrowband imaging. I have the ZWO Ha , OIII , and SII filters and have tried them out. This is probably a stupid newbie question, but should I see anything in the preview in the ASIAir app? I know I am on the object because when I shoot using the L filter, I can see it. When I try shooting with the any of the narrowband filters I don't see the object. I know I have read that I need to do some post processing of the images but I have seen some videos where they are using the ASIAir and they shoot for instance a 60 second image using a narrowband filter and they can see image data. Thought i would chekc in this forum to see if there is a step I am missing in order to be able to see it in the ASIAir. Thanks for any help.
ASIAIR Plus Narrowband
Yes, you should see something. If you're not, take longer exposures. Try 2 minute (or longer) exposures.
- Edited
codemanwa When I try shooting with the any of the narrowband filters I don't see the object.
Is the object that you are imaging an emission nebula?
If it is a reflection nebula, you are likely going to see nothing through one of the standard "narrowband filters" -- the passbands of the filter and the reflection nebula simply don't overlap.
If you are imaging a galaxy or stars with a narrowband filter, expect to need an exposure time that is equal to about 300/W times longer, where W is the passband (in nm) of your narrowband filter.
In short, never use a narrowband filter with anything but emission nebulas, unless you want to add some particular regions (e.g. H-alpha) to an existing LRGB image.
With good filters, expect about an extra 10% of exposure time with the emission nebulas. If you are using the ZWO filters, expect to expose for at least an extra 20%. (You should have checked the specs before buying it. Caveat Emptor.)
Just remember that a narrowband filter does not make a nebula brighter, it simply makes what is not an emission line dimmer; and that produces the better signal to noise ratio for the emission lines. And it almost always makes a star much dimmer.
w7ay Hollow Chen, it's been a while !!
I seldom post anything here, but do stop in every morning and read any new questions, and responses. I ALWAYS read your responses even if the subject matter is not a current concern of mine.
In any case to the point of my comments here:
Have you ever considered writing a book on the general subject matter this site covers? My God in just the couple of years I've read your comments you certainly have maticulously answered hundreds of questions and in the process done much to educate as well as enlighten all of us.
Your response here to codemanwa is another good example....
Personally I very much appreciate the time and detail you put into your responses, they are far more educational than most of the You Tube "experts". Even if sometimes a bit overly complex, I do know that if I take the time to understand what you're driving at, I will find that time, time well spent.
I hope you have some file where you save your responses to all the questions you have answered here because if you do this hypothetical "book" of your's I am suggesting, is already largely written :-)).
Lastly, if you do follow up on my suggestion please reserve for me an autographed first edition copy as a "reward" for my idea :-)
BTW bummer on your Boilermakers in the first round of the NCAA's :-(
Best Regards. Al
Byrdsfan1948 Have you ever considered writing a book on the general subject matter this site covers?
Heavens, I don't think I have time to do that, Al!
Most of the stuff can be gleaned through experience anyway (just stay away from YouTube shills). I also often leave some bread crumbs on where to read more about a subject. Technical hobbies require dedication. Remember what Euclid told Ptolemy when the latter asked for a short cut to learning Geometry?
That said, I am currently writing up a white paper on guiding mounts with high harmonic distortions, because the assumptions made for driving such mounts is just wrong for such mounts.(Actually not much is written, except for the code itself, so you have to deduce the assumptions.) Just wait a couple of weeks.
No kidding. And the also 1-seed Stanford WBB getting wiped out in the second round in their own home court, too. No March Madness for me this year :-).
BTW Al, did you know that the inventor of the strain wave gear came from your alma mater? This is cut from my white paper:
Thanks everyone for your responses. Sorry for the long delay with following up, the weather here has been pretty bad up until about a week ago when I was able to try again using some additional targets. Gong back into another 10 day stretch of bad weather so I had a 3-day window to try again. I have tried these targets: NGC 7635, IC1805, IC1848, and NGC7000. I haven't had any luck with them. I am using this camera and filter kit: https://optcorp.com/products/zwo-asi1600mm-pro-125-kit . I am wondering if I am missing a step in my workflow. I tried taking exposures 300 seconds + but still no luck with any of the narrowband filters. I did notice that on NGC 7000 when I tried with the Luminance filter, I do see something but not sure it's the nebula Unfortunately, I am a little limited on what targets I can work with due to trees obscuring my view in the western sky. I have heavy light pollution to the north where most of these targets are but thought that it shouldn't be a problem for the narrowband filters. I have had pretty good success viewing/imaging targets that are not narrowband targets. Thanks again for any ideas for troubleshooting further.
- Edited
codemanwa I haven't had any luck with them.
Did you postprocess and stack your images?
First, remember that the filter wil not make the nebula any brighter, it simply makes the background sky and stars dimmer, while the good narrowband filters will only attenuate the nebula by a little (cheap narrowband filters will attenuate more, and require longer exposures). A narrowband filter basically makes something like a Bortle 7 picture look like Bortle 4 to 5 picturer, depending on how narrow band it is -- the narrower the passbands, the darker the sky. And they only work with emission nebulas.
A single frame with a slow OTA will still show very little brightness, even for something as bright as NGC7000. They just need to be properly histogrammed (stretched) with post processing.
Here is a single ASI2600MC 180 second, gain 100 image of NGC7000 on an FSQ-85 with a 0.73x reducer (330 mm focal length @ f/3.8), and a Radian Quad filter):
If you have an f/5.6 OTA, expect to expose an ASI2600 with gain 100 for 360 seconds to get the above, and with an f/8 OTA, expect to expose for 720 seconds to get the same brightness. With gain 0 (10 dB less gain), and a f/8 OTA, until histogrammed properly, the single frame would show almost nothing with a 300 second exposure.
Next is a stack of just 6 of the above captured images, and postprocessed with AstroPixelProcessor, Affinity Photo, and macOS Preview (equivalent to a 1000 second exposure at f/3.8 and 10 dB of camera gain):
Remember too that nebulas are extended sources; so, fast f-numbers help, no matter whether you are undersampled or oversampled for stars. The above images are basically a little faster than f/4. With a f/5.6 scope, you would need to double the exposure time to get the same image, with an f/8 OTA, you would need 4x more exposure time (total integration time of 4000 seconds, with ASI2600 at gain 100) to get the second image.
Avoid cheap filters; you get what you pay for. I know it is too late for you. Get at least Antlia or Optolong quality class. If you can afford it, get Astrodons and Chromas. You will eventually get disgusted with the cheap filters, and end up in total paying more when you end up upgrading the filter (this is how the poor becomes poorer). Cared for properly, filters last a loooong time; treat them as a long term investment. Thay will outlast many, many cameras as long as the size is suitable for future cameras.
With NGC7000, for example, look at the bright star Cyg Xi -- the bright star near the bottom right of center in the above images. Cheap filters will show bright halos and other aberrations. With the Horsehead Nebula, the Orion belt star Alnitak is a good star to judge quality of a filter.
With respect to your comment about Luminance filter -- with a good narrowband filter and the same exposure settings, (1) the brightness of NGC7000 nebula itself with the H-alpha filter should be really close to the brightness with the Luminance fiter, and (2) the background sky with the narrowband filter should be virtually black compared to sky background with the Luminance filter. If both cases are not true, return the narrowband filters, since those are the bare minimum of what basic narrowband filters are supposed to deliver.
By the way, I notice you are also using a ZWO filter wheel. Those wheels have terrible light leaks right around the white stepper motor. Make sure you use black electrical tape and tape off the gaps between the motor and the metal body of the wheel. Be sure not to tape over the shaft and bearing (there is no leak there).
Thanks Chen, no I have not postprocessed or stacked the images yet. All of my testing has been focused on using the ASI AIR Plus and just getting oriented with it. I thought on my next attempt I would try the out of the box live stacking on the ASI Air Plus device. The focal length of the scope is f/6.5 so perhaps I will go to an even higher exposure and try the live stacking and see what happens. I wish I had more money for better equipment and should have researched the filters before I bought them. I have had them now for 5 years and just finally making use of them so your right it's a little late to return them.
Jim
- Edited
codemanwa I thought on my next attempt I would try the out of the box live stacking on the ASI Air Plus device.
Don't do that. Use proper tools. AstroPixelProcessor is well worth the money and works well even if you just let it use its well thought out default settings.
If you have any field rotation at all, the ASIAIR live stacker will not give sharp corner-to-corner stars. With large enough field rotation over a long session, it may not even stack. ZWO's free software is not worth wasting time on either; you get what you pay for.
I can give AstroPixelProcessor a try. I guess the reason why I was planning to try the out of the box stacking on the ZWO ASI Air Plus device is so that I could see whether I actually have the target while doing the imaging session. Seems like it would be helpful to first see whether I have what I am trying to image directly on the device during my session without having to offload the images to my computer and do processing. I agree that ultimately, I would want to use post processing software as you suggested. I am still confused why I don't see anything. I have watched several asi air plus tutorials and in the tutorials, they do narrowband imaging, using identical equipment (including the zwo filters), and exposures around 60 seconds and they are seeing an image in preview.
- Edited
codemanwa I am still confused why I don't see anything
Are you seeing nothing after stacking? If so, the passband of your narrowband filter may be in the wrong place.
If you can see the nebula with a Luminance filter, a real Hydrogen alpha filter should give virtually the same brightness (with same gain and exposure time), but with much darker sky background. If your exposure time and gain with the Luminance filter shows the nebula, but a narrowband filter does not when using the same camera gain and exposure, there is something seriously wrong with the filter.
The Bubble nebula will be dim with a visual magnitude of +11. The Heart and Soul Nebulas are a quite a bit brighter at M+6.5. And of course NGC7000 is horribly bright, at M+4.0. So, for starters, I would focus [sic] on North America first before you get things sorted out.
With NGC7000, try the narrowband Hydrogen Alpha filter -- as you see from my NGC7000 image, it is much more abundant that Hydrogen-Beta or Oxygen III (the part that contributes only a slight bluish tint when it is combined with the deep red of the Hydrogen Alpha).
Since it is not that far away in the sky from NGC7000, and has even lower declination (so it is higher in the sky for most people in the northern hemisphere), you could try the nebulas in the Cygnus Loop. The Western Veil (NGC6960) is actually quite bright (M+5.0) and has very strong O-III/Hydrogen-beta in the filaments.
Likewise, the Eastern Veil is equally bright, and also has a lot of OIII/H-beta.
Both veil images above are cropped from a single large frame of the Cygnus Loop at 330 mm focal length taken in the Autumn of 2020 -- if you have a longer focal length OTA, just go to each one of the above separately. They are not as bright as NGC7000, but is a good test of both H-alpha and O-III filters. The uncropped Cygnus Loop at 330 mm focal length and an APS-C camera looks like this:
Before stacking and proper stretching of the 56 three-minute sub frames, one sub frame looks like this:
So, don't be discouraged if you only see a very dim image, especially if you have a slower OTA. Just postprocess it with a decent program to stack a couple of hours worth of images. May take more than a night's worth of image collection for the dimmer stuff. Just do not use software from ZWO to stack.
This is the Heart and Soul together, using a 200 mm focal length OTA and the cheaper Optolong L-eNhanced filter:
But since they are dimmer (requiring 4 times longer exposure, all else being equal, than the nebulas in the Cygnus Loop) I would also do a pass on them and just use NGC7000 and the Cygnus Loop to test with. NGC7000 is blindingly bright, and shouldn't take more than an hour worth of exposures to get some results, but the Veils are higher in the sky and may be more convienient (and able to test the O-III filter too).
Daft question - Do you have the histogram set to auto ?
Also thumbs up for the Astropixelprocessor recommendation. Does a much better job stacking S50 images.
