Again, I'm using ASCOM V6.5.15.0323 beta with firmware 1.2.4 beta.
I have reported before, under beta 1.2.3 thread, that when using NINA to send the park command, the mount would go Home. Last night is sent the Park command from NINA and the scope went west and level, pointing to the horizon. So I can confirm that the mount does the right thing now.
However, just like I've reported before, after the Park command from NINA, the mount will not track unless I turn off the power and then turn it back on. After I did the Park, I send the Home command, then I pointed it to a focus star (recommended by NINA). So go-to commands still worked. I could not focus because the star was always moving. That's when I realized there was a tracking issue.
1) The tracking light on the hand controller was on. When I pushed the track button on the controller, the light turned off, and it would never come back on after pressing it again.
2) In NINA I sent the command to set tracking = sidereal. Still no tracking. So plate-solving failed and I couldn't continue.
3) At this point in time I reset the power and everything went back to normal.
Looking back, I did not try sending the Unpark command from NINA. I don't know if that would make a difference...
Is there anything else I can try? Is there a specific Unpark routine that I'm not following?
This Park feature is not very useful to me. I would like to park pointing south and level, preferably on the right side of peer, but left would be OK too.
Thanks!
