Domenico_Cat89 Let me know your idea/opinion/advice or anything that might be helpful.
Check if
(1) the auto flat panel is 12V operated,
(2) that it is possible to make it flip by using 12V trigger signal.
If so, you can wire it so that it takes power and trigger signal from one of the DC outlets of the ASIAIR, and control it that way. Ask deepskydad.com if his auto flat panel can can be operated this way, and/or if he can make a couple wiring changes so it can be operated this way. Pavel is very flexible with customizing his products.
