Many club observing outings and star parties prohibit using a white light. I’ve built a box to hold my iPad with a rubylith (red) panel covering the iPad display. It works great to eliminate white light while using my ASIAIR+ but the red wavelength also eliminates all green-blue lettering used by the ASIAIR+. Examples are polar alignment readout on adjusting altitude and azimuth, RA guide graph, etc.
A simple black background with white letters/ numbers would solve the problem. Perhaps an option in the ASIAIR+ for the display colors.
I’ve received some complaints at observing events when I slide my iPad out of its box to read important information. Help us out here!
    PhotomanTom my iPad
    iPad > Settings > Accessibility > Display & Text Sizes >Color Filters
    Turn switch on.
    Select Color Tint.
    Set Intensity Slider to maximum (right)
    Set Hue Slider to either far left or far right.
      14 days later
      w7ay Finally got around to resetting the iPad screen display. The screen was red with diminished illumination BUT, could not do polar alignment because couldn’t read the green lettering for amounts of adjustment in altitude and azimuth. This result is similar to using a rubylith film in front of the iPad screen.
      The only option I see is for ZWO to give an option in the ASIAIR+ to display white text with a black background. It would be very readable and not produce a lot of white light. Even less white light with a rubylith film in front.
      I annoyed my son (visual observer) and possibly others at his astronomy village when I had to try and shield the white light from my iPad, I thought inside my shirt, until he commented.
      ASIAIR+ is a great device BUT creates issues for others. I could control my computer screen’s white light with the rubylith film. HATE the green and blue text and number choice by ZWO!
      a month later
      +1 on this. It's ironic that a specialized application for astrophotography does not have an option for dark skies-appropriate UI theme
      Write a Reply...
