Hello ZWO,
the problem still exists withe the new ASCOM driver: Pls. take care.
2023-06-03T08:14:10.9933|DEBUG|AscomDevice.cs|Connected|141|SET ZWO Focuser (1) Connected to True
2023-06-03T08:14:12.0700|ERROR|AscomDevice.cs|GetProperty|353|An unexpected exception occurred during GET of IFocuserFacadeProxy.StepSize:
ASCOM.DriverException: CheckDotNetExceptions ASCOM.EAF.Focuser StepSize Get System.NotImplementedException: Die Methode oder der Vorgang sind nicht implementiert. (See Inner Exception for details) ---> System.NotImplementedException: Die Methode oder der Vorgang sind nicht implementiert.
--- End of inner exception stack trace ---
at ASCOM.DriverAccess.MemberFactory.CheckDotNetExceptions(String memberName, Exception e) in C:\ASCOM Build\Export\ASCOM.DriverAccess\MemberFactory.cs:line 629
at ASCOM.DriverAccess.MemberFactory.GetTargetInvocationExceptionHandler(String memberName, Exception e) in C:\ASCOM Build\Export\ASCOM.DriverAccess\MemberFactory.cs:line 664
at ASCOM.DriverAccess.MemberFactory.CallMember(Int32 memberCode, String memberName, Type[] parameterTypes, Object[] parms) in C:\ASCOM Build\Export\ASCOM.DriverAccess\MemberFactory.cs:line 287
at ASCOM.DriverAccess.Focuser.get_StepSize() in C:\ASCOM Build\Export\ASCOM.DriverAccess\Focuser.cs:line 191
at Castle.Proxies.Invocations.IFocuserFacade_get_StepSize.InvokeMethodOnTarget()
at Castle.DynamicProxy.AbstractInvocation.Proceed()
at Castle.Proxies.IFocuserFacadeProxy.get_StepSize()
2023-06-03T08:14:12.1741|INFO|AscomDevice.cs|GetProperty|327|Retrying to GET IFocuserFacadeProxy.StepSize - Attempt 2 / 3
2023-06-03T08:14:12.1769|ERROR|AscomDevice.cs|GetProperty|353|An unexpected exception occurred during GET of IFocuserFacadeProxy.StepSize:
2023-06-03T08:14:12.2783|INFO|AscomDevice.cs|GetProperty|327|Retrying to GET IFocuserFacadeProxy.StepSize - Attempt 3 / 3
2023-06-03T08:14:12.2890|ERROR|AscomDevice.cs|GetProperty|353|An unexpected exception occurred during GET of IFocuserFacadeProxy.StepSize:
2023-06-03T08:14:12.2890|INFO|AscomDevice.cs|GetProperty|358|GET IFocuserFacadeProxy.StepSize failed - Returning last known value 0
2023-06-03T08:14:12.3227|INFO|FocuserVM.cs|ChooseFocuser|307|Successfully connected Focuser. Id: ASCOM.EAF.Focuser Name: ZWO Focuser (1) Driver Version: 6.0
