Hi, I have that setup and it works great with the ASIAIR mini. The difference with the pro and plus versions are not as relevant or necessary for what you want to do with their components. With the mini version you will not have a power button, all the USBs are 2.0, you do not have an ethernet port and neither a USB drive. The power button is not necessary, the transfer speed of USB 2.0 is not as appreciable already in use, you will not need the ethernet port if you are not going to use the PC or some other accessory and if you need more capacity you can place a hub to expand the USB ports and put a memory expansion there. You can use the mini version for your setup without problem
