Hi
Gone through the hoops on this one.
Asi Air pro, Vixen SXD2/Starbook 10, 533MC Pro main, 178MM guide
When taking a sequence of guided light frames, I will get random disconnects (maybe two per session) of BOTH mount and guide camera. No warning. No alert. Guide graph just stops, main camera will continue shooting, stars will trail, target will drift.
Both will be greyed out in the AAP app and I have to flip the screen toggles back on. Guide camera usually shows up as 'none'. Usually have to re-select the 178MM although sometimes it isn't there (no option but none)
I can get that a USB or camera issue could cause a dropped connection, but what would cause both mount and guide camera to disconnect simultaneously?
Edit: AAP is connected to a 750 Slate router by shielded LAN. LAN connection to SB10. 5GHz Wifi connection from tablet to router.
I've changed all the original USB cables to good quality aftermarket ones, all bundled and secured. I have separate 13.6V supplies to mount, AAP, and 533MC camera so I'm pretty sure it's not power or voltage related. I've even added a Pegasus Powerbox Micro to take the load off the ASI Air Bus but no change...
