Kentmd There are various sizes so not sure which would work this is 2 inch with .8 inch draw is this what you mean?
The 2" FTF comes in various styles. The common part is that they all have the same dovetail to attach to the OTA end (also doubles as a rotator to orient the knobs).
If you buy the "Borg version" of the FTF (FTF2008B-M57), you get the adapter shown above. The thread is the M77.6 thread that Borgs use for their 80mm tubes. The drawtube of the "2008" FTF has 0.8" travel (the "2015" has 1.5" travel, etc).
The drawtube of the Borg model is threaded at the "camera end" with a male M57 thread (thus "Borg").
If you prefer to get a 2" eyepiece holder at the camera end, you can buy any of their other 2" FTF, but specify that you want the M77.6 adapter for the telescope end.
You can also get the adapter from PreciseParts.com, by specifying 2" FTF to Borg M77.6. I have a PrecisePart adapter instead of the one from Starlight Instruments for a Mewlon, since I wanted a shorter FTF adapter than the one Starlight sells for the Mewlon.
The M77.6 thread is really only useful for the 80mm Borg tubes. The FTF is really large and heavy for adapting to the Borg 60mm tubes.
For the 2" eyepiece holder on the camera end, you can get other drawtube lengths. The FTF2008B-M57 is equivalent to their non-Borg "Shorty", with 0.8" travel. For the 2" focusers, they also have models with 1.5", 2" and 2.5" travel. Additionally, Starlight have models where some of the metal is hollowed out to be lighter (perfect for the Borg lightweight paradigm -- so I have one of those too).
You can pretty much mix and match FTF stuff, even though it does not show up on their web pages. Just email them.
If you remove the FTF focuser lock screw, you can attach a ZWO EAF plate to that.
If you don't care about ASIAIR compatibility and want an electronic focuser, Prima Luce makes a really nice one (Esatto) that has adapters for Borgs (2" version for 55FL and 3" for 90FL and 107FL). Check out Ishikawa-san's web site digiborg.wordpress.com.
