maplearn hello
1 Connected the mount. Find the Mount Control Panel in Preview. Tap the coordinates below the Go button to modify. After modifying the coordinates, tap Go, and the mount will GoTo to the target position
2 In the Object List - My Favorites, you can add custom coordinate targets. You can first add a target with fixed coordinates, then Goto this target
