Astroblue17 images come circular white like what is attached
I see a light dropoff only when I stretched your image:
Perfectly normal, and often worse for non-astrographs. With camera lenses, you will find a smaller dropoff by using a dimmer f-number. I.e., an f/11 will have less dropoff than f/2.8.
You get around this by taking "flat frames" (Google it) at the same f-number and focus and with the same filter as what you used for your actual image. And then use the flat flames to correct the images during post processing.
