Let me know if the logs will be helpful, basically I was out imaging over the weekend. Everything else worked as it should but I got "Meridian Flip Failed" message 4 times before it finally succeeded on the 5th attempt. The error in the log was something along the lines of 'wrong pier side' which I validated by going outside to look at the time.
Eventually, it sorted itself out, actually slewed to put the OTA on the correct side of the pier, plate solved, and I was on my way. I didn't do or touch anything to make it fail or to fix it.
Any ideas? I don't think I have seen it do that before.
Adam
