hello everyone, I am a new user of ASIAIR PLUS and the cameras 533mc pro as main and 120mc as a guide, these days has been cloudy and I have not been able to make any light shots, but I wanted to make a dark library and I have had the following problem, once it has made the shot, sometimes it gets stuck in the image recording and there the cooler is disconnected and the camera loses the temperature reached in this case of -10 degrees, once it manages to write the image the camera returns to have on fan on but has already lost the temperature.
This has happened to me in shots of all types 30s, 60s and especially in long shots of 120s 0 300s, the problem is that if this happens then the images that are supposed to have recorded can not be seen and the biggest problem is the loss of temperature in the sensor that goes from -10 to temperatures above 0 degrees, the ambient temperature was 20 degrees.
The connections are the cameras by usb 3.0 to the ASIAIR, the EAF focuser to the USB hub of the 533 camera and the power supply of everything is the ASIAIR by the ZWO power supply (12V and 5A) and the 533 camera takes its power from the ASIAIR by one of the 4 outputs.
What could be happening, as I have not seen temperature oscillations (+- 0.5 degrees) if the camera is simply turned on without doing anything, it only happens when doing autorun shots.
I hope you can help me, thank you very much!!!!
