OklahomaProf1940 I have uploaded screen captures of files showing an individual 60 second dark frame
Seems like a single light frame looked OK until you calibrated the stack with your master dark frame.
That leads me to think that there is a light leak when you took your dark frames.
Did you happen to take the dark frames in a brighter environment than the location where you took the light frames?
Remove the camera from the OTA, and cap the camera flange with a metal M42 cap. Try taking your dark frames again after that, to see if the problem persists. If the problem goes away, you have a light leak.
If you are using a ZWO filter tray or ZWO filter wheel, those would be the prime suspects for leaking light.
