heyjp (The scan sees neither).
Hi Jim,
Have you tried using a "travel router," and connect your two ASIAIR and your iPads/iPhones to it? I.e., let the travel router be a common DHCP router. That might make ZWO's implementation of Zeroconf work better. And the travel router can be close(r) to the ASIAIR.
They are really cheap and works off USB power:
https://www.amazon.com/TP-Link-Wireless-Travel-Router-TL-WR902AC/dp/B01N5RCZQH/
https://www.amazon.com/GL-iNet-GL-SFT1200-Secure-Travel-Router/dp/B09N72FMH5
The travel routers can be configured to be its own network, and using some other router on a different network (e.g., your home network) to connect to the WAN, if you need internet services.
Indeed (at least with the Opal), if you have Cellular tower within sight, you can ask the router to use a "Mobile hotspot" as the WAN spigot, and that will give your devices (like iPhone that is connected to the travel router) access to the internet too.
https://www.t-mobile.com/hotspot-iot-connected-devices/jextream-rg2100-5g-mobile-hotspot
Not only that, if the ASIAIR has a problem reaching your router even at home, just use one of these hotspots to get to the internet (cell tower) directly instead of through your home network.
(You need to add the Mobile hotspot as a line to your exisiting cell phone contract. They exist to make money, so you just need to make money faster than they can suck the money away from you :-) At least T-mobile is "all-you can eat", as long as you don't mind being throttled when you exceed what you paid for.
