I’ve just picked up a 7x36mm EFW and a 2600MM and the EFW included 2 slightly different pairs of “darkening set” shims … one pair for each side of the EFW.
The instructions on the EFW product webpage only shows the darkening set (black shims) being used in OAG-EFW-Camera setups which are presumably screwed together. There is no guidance for a threaded setup.
In my case, I don’t use an OAG and I’m using threaded connections Focuser-EFW-camera with the 2mm T2-T2 adapter in between the EFW & camera (with the tilt plate in place).
Do I need to use the darkening set shims and if so, how are they secured when threaded adapters? There is no pressure to hold those shims tight and prevent the leaks (especially on either side of the T2-T2 2mm adapter.
