I have a BAADER STEELTRACK on my C11, and I just got my order of the EAF Problem, how adapt it on the C11 ? As you can see on the pictures, the EAF can't fit exactly ? Thanks for you answers and Clear Skies... MASTRO MORE
michelmorenoparis I suspect the shaft on the focuser is too long to cause the shaft of the EAF can not insert to the end. It's enough to fix it, no need to totally insert to the end. Also, pay attention to needs to fix the set screw to the flat
Tech@ZWO
OK Thanks for your answer... KR
TJ Connolly 3D printed me a mounting bracket for my SteelTrack & 9.25 Edge
