Hello TomaszZielinski hello juliorgoni  hello Tech@ZWO
I have exaclty the same setup. and the same problem.
I have an asiair pro connected to a skywatcher flextube 250P.
and i have issue the mount go-to, it run far away in random position.
what i do:
1) Turn on the telescope and Asiair, then connect to the home AP.
2) Everybody gets its IP address. They can see each other, and everybody is happy.
3) The telescope is turned on in its default position: flat, pointing north (N0, E0).
4) On the Syscan App (on Android phone with an accurate GPS position), I perform a 2 or 3-star alignment.
5) I connect the mount in Asiair (using Skywatcher az/gti/syscan wifi) with the IP address of the mount and the UDP port 11880.
6) ensure that the gps position is accurate!
7) take a picture, plate solve, and sync to the mount.
At this point, everything should work perfectly but it still goes random.
I've notice a new alert sing that says "Ensure DST is disabled on Mount Hand Controller. It's normal that the time on the Mount is 1 hour earlier than local time" where i can check this option in the syscan app . i've try to set if off on the mount hand controller. i but doens't change anything.
Did you get it to work ?
thanks for you help and for sharing  π
