bguthrie I am super excited to be able to do this on my Mac
OK, this is using Lynkeos to do everything (with some touchup at the end with macOS Preview).
I had captured the images using ASIAIR into FITS (600 x 0.02 second exposures with gain=0). 50mm etalon as before. AutoStakkert does not take FITS images, so I jsut used Lynkeos to stack a bunch of FITS that I simply dragged and dropped into Lynkeos (I did tell you that Lynkeos is very Mac centric, right?).
Passed the aligned and stacked images to Lynkeos' Richardson-Lucy blind deconvolution, and passed that into Lynkeos' Wavelet filters. Finally sharpened the result a smidgen more in macOS Preview, and adjusted the dark and white levels a little.
The solar disk is a little smaller than 2400 pixels in diameter (901 mm focal length, ASI533MM pixel size) and the above is just a small unscaled 400 x 400 pixel crop.
I then did a 2-step Richardson-Lucy (reducing blur circle between steps) + Wavelet filter and touch up in macOS Preview, and got this (notice finer structures) for a different region of the Sun:
Full image can be found here:
http://www.w7ay.net/site/Images/Sun_May_14_2023.png
You can play around quite a bit with Lynkeos (nope, cannot do any of this in ZWO's application).
Image of the instrumentation is in a different thread:
https://bbs.astronomy-imaging-camera.com/d/16315-aspect-ratio-bug-in-asiair-preview
