elpajare Creating an option to be able to enter the AR and DEc of these items would help a lot.
There is a workaround (not pleasant, but workable) that can be used. I have used it all the time (for example, recently to get some coordinate between M81 and M82 to place the center of the camera FOV).
Get into the View Objects window. You can get to it easiest by tapping on View Objects in the Telescope Setup window.
Pick My Favorites from the hamburger icon at the far top right.
Tap on Add near the bottom right of the My Favorites window.
Give the target a name, and the RA and declination coordinates by tapping on each text field, or if you are already centered on the target, just tap on "Use Current Position of Mount." The RA and declination entry will be done through three vertically positioned Pickers (scrollable lists).
Tap OK, and you now have a target in My Favorites to go to (and for use in the future).
Not a direct way to GOTO, but passably works. And useful if you want to go to the same target again in the future.
To remove, get to the My Favorites window. Then swipe the target entry all the way to the left. A Delete button should then appear on the far right side of the target.
