Yeah, follow what Corsair said.
You typically do not have to set the time in the hand controller.  Simply turn the Daylight Saving Time (DST flag in the mount off, and let the ASIAIR (in the tablet) push ("sync") the time and location to the mount.  From monitoring the USB traffic, ASIAIR appears to "sync" by itself right when it connects to a mount (it used to be haphazard, but the recent versions of ASIAIR appear more consistent).
However, there may be mounts that are stubborn and will reset the time back again.  For those mounts, you will need to set the handcontroller's local time manually.  FWIW, I do not have to do that with the RainbowAstro mount.  I don't even use my hand controller when using ASIAIR -- I simply turn DST off.
Much of this "stubborness" comes from the GPS that are in some mounts (i.e., the mount will try to use GPS).  If you have GPS in your mount or handcontroller, turn the GPS off, although just turning DST off will often do the trick.
Basically, ASIAIR only understands Winter time.  China does not use Daylight Saving -- Korea also does not use Daylight Saving, but the RainbowAstro mount understands it perfectly.  So it is no excuse.
So, just undo the "Spring forward, Fall back" like you do on your clocks and always use Winter time as the local time for your mount  even in Summer (turning the DST flag off will also adjust the UTC offset).
All this is because of a huge bug in ASIAIR code.  The ASIAIR is using Local Time (which therefore involves DST) as part of the computation for the fundamental time for astronomy called Local Sidereal Time (LST).
LST depends on UTC (Universal Coordinated Time, referenced to the Greenwich Meridian) and your local longitude.  It does not depend on Local Time -- I don't know which school ZWO went to, to learn the wrong stuff.  And after years of being told to use only UTC and longitude (I even emailed their higher ups directly), they persist on using Local Time, all for the sake of the lowest common denominator - moronic customers who do not know what UTC is, and only know the time on their "smart watches."
