It would be wonderful if you built a clutch into your EAF. I often switch back and forth from C11 0.7x (1960mm FL) to C11 w/Hyperstar (530mm FL). At the moment I loosen the screws on the EAF side of the connector to get a rough manual focus before using EAF. It would be wonderful if the EAF had a clutch.
