Hi all,
I just made the big step after years of using an AVX and picked up a ZWO AM5. I feel that the guiding could be way better for this mountand i'm sure its settings that i'm not doing correctly. I'm seeing numbers around 0.67 and then over the course of the night I'm seeing these numbers increase despite being under bortle 4 desert skies with crystal clear seeing. Polar alignment is spot on. I primarily use the Polemaster for polar aligning, and have also used the ASI AIR polar alignment tool. I strictly use PHD2 for the guiding software. Even when using the ASI AIr guider i'm seeing around the same numbers.
Within PHD2 I created a profile, ran a calibration to the south above the celestialequator as described in the best practices. After calibration, I also ran the guide assistant for about 5 minutes and applied the suggested numbers and then started imaging using predictive pec, and resist switch. As stated the numbers are slightly underwhelming and steadily increase over the night.
Looking for suggestions from people as I can't seem to find what this thing likes for settings.
My gear is a Stellarvue SVT70-IS, ASI174MM Mini guide cam, ASI294MC Pro, ZWO EAF.
Attached is lastnights guide log. The one that starts at 00:15 for 3hrs 1m was my main imaging run. After that run you can see where i'm playing around with settings, but the numbers keep increasing.
Link to the guide log
https://www.dropbox.com/s/cm1kv2zqawjfcqa/PHD2_GuideLog_2023-06-17_102840.txt?dl=0
